Insulation Identification - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 10:20 PM   #1
Question
I have a water heater from about 1960 that I started salvaging the tank from and I am a bit suspect as to what the insulation might be. My first impression was that it wasn't asbestos, but the more I work with it, the more suspicious I become.
It is a loose pack that consists of fine fibers about 3/4" - 1" long that easily disintegrate into a powder as the material is handled and seems to be somewhat heavier than I would expect. The attached pictures show the color. So far, I haven't had any luck finding pictures that look anything like it.
Can anybody give a reasonably certain yea or nay on the asbestos content or suggest other properties to check for that would give me an answer?
tomshouse is offline   Reply With Quote
Old 12-11-2010, 10:28 PM   #2
Let's see if I can get the pictures to stick this time...
Insulation Identification-dscn0007d.jpg   Insulation Identification-dscn0007c.jpg
Old 12-12-2010, 07:22 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Looks like 50 year old rotten Fiberglass to me...
The Following User Says Thank You to Bondo For This Useful Post:
tomshouse (12-12-2010)
Old 12-12-2010, 07:59 AM   #4
Would have been called glass wool or rock wool then. May or may not have asbestos, but a good dust mask is needed, regardless.
The Following User Says Thank You to Just Bill For This Useful Post:
Old 12-12-2010, 01:13 PM   #5
It is indeed very rotten.
Bill, the first thought that popped into my head when I saw it was "rock wool", so thanks for the confirmation. More googling has turned up nothing about asbestos ever being orange, so I'll consider the odds low, but since it is a relatively nice day today, I think I'll take it back outside for the rest of the stripdown.
Thanks for the replies.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
