Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-01-2011, 06:06 PM   #1
Insulation between garage and bathroom above
We are remodeling the master bath which happens to be above the garage. Currently there is R-22 insulation between the two. I want to add some more to that, but am unsure of the easiest route to get it there. Should I pull up the subfloor, add batting and then new subfloor? OR should I make holes in garage ceiling and blow in some more insulation? Or make holes in subfloor to blow in more? How much more insulation can I add? The joists are engineered I beams that are 12 inches high and 16 inches apart.
thanks in advance
Mindy in Richardson, TX
zmindyk is offline   Reply With Quote
Old 11-01-2011, 06:26 PM   #2
I'd pull the ceiling down and spray a closed cell foam in there.
Ron
B. Franklin 1759
Old 11-01-2011, 06:29 PM   #3
I hear that can be fairly expensive, and I am not certain it will fit in the budget at this time. But maybe I am wrong on the cost.
Mindy
Old 11-01-2011, 07:21 PM   #4
Anyone know what a double garage approximately costs to foam insulate in the Dallas TX area?
Mindy
Old 11-01-2011, 09:30 PM   #5
Assuming that the R22 insulation is in batt form and that there is a vapor barrier under the subfloor, I would suggest that you would blow cellulose insulation into the cavity that is between the insulation and the vapor barrier.
The cellulose can be blown into the cavities by drilling 1" holes through the subfloor.
After the joist cavities are filled, close the drilled holes using expanding foam insulation.
Old 11-01-2011, 10:12 PM   #6
Msradell's Avatar
The only way to go! We used this solution a couple of years ago in exactly the same situation. The change in temperature of the bathroom is huge! You should at least check the price, it's probably not as bad as you're thinking.
Msradell is offline   Reply With Quote
Old 11-01-2011, 10:35 PM   #7
Yes, the current insulation is in batt form with the attached vapor barrier to the underside of the upstairs floor. So blowing from the top would put insulation, vapor barrier, insulation.
Mindy
Old 11-01-2011, 10:36 PM   #8
Do you know how many inches of foam you used? Just curious.
Mindy
Old 11-01-2011, 11:27 PM   #9
Mindy
The foam is rated @ R5/inch!
Old 11-01-2011, 11:29 PM   #10
Mindy
The cellulose fills the void between the existing insulation and the vapor barrier that is immediately under the sub floor.
Old 11-02-2011, 11:42 AM   #11
Msradell's Avatar
Mindy
We put 6 inches of closed cell foam (about R-40). The big advantage is not only does it provide insulation but are also completely prevents air infiltration.
Old 11-04-2011, 12:36 AM   #12
Moderator
You would still get a temperature difference from the cold garage air (thermal bridging), similar to a crawl space. You would also need a foam board under the new 5/8" fire-rated drywall. I would add more fasteners to the drywall, and possibly wood strapping, for the added weight of 12" of cellulose.
http://www.buildingscience.com/docum...n-crawlspaces/
http://gypsum.org/pdf/GA-216-2010.html
Gary
Clothes taking longer to dry?
Bathroom in the garage. Is this dumb? grabbag Building & Construction 16 06-02-2011 04:30 PM
electricity out in garage???? a68cudas Electrical 6 07-04-2010 12:34 PM
Questions about insulation in basement remodel BillG Remodeling 1 04-27-2010 09:15 AM
Cold bathroom toeey1 Roofing 5 02-10-2010 08:29 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 11:56 AM
