Insulating Pipes - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 08:40 PM   #1
insulating pipes
Hi from Earth Texas. Can anyone help me with ideas about insulating a north walled utility room so that the pipes won't freeze.There is quite a bit of insulation in the wall and the pipe themselves are packed but we have had two below zero cold front and snow in the last week and both times they have frozen ( pipe sprung a leak once, had to repair). It came another one today and they are frozen again.Is there a energy efficient way to put more heat in there? Any suggestions appreciated!! charlie
charliesioux is offline   Reply With Quote
Old 02-08-2011, 09:12 PM   #2
Rewards Points: 290
Are you saying this is unusual weather for your region? Why go to the expense of a permanent fix for a temporary problem. You can have all theinsulation in the world but you don't have an adaquate heat source, you are still going to have pipes freezing. Why not get a safe space heater in there till the weather woarms up? I had a landlord years ago who set up a 200 watt flood light aimed at the direction of his water tank and pipes in the pump house which worked after the pump froze.
Jim F is offline   Reply With Quote
Old 02-08-2011, 09:34 PM   #3
Yes this is unusual weather for us to get 7 or 8 below.We have some really cold weather but not this cold. I was thinking maybe just a heat lamp might work. Thanks for the info. CS
Old 02-08-2011, 10:38 PM   #4
Leave a faucet trickiling to avoid pipe bursts
bbguy5 is offline   Reply With Quote
Old 02-09-2011, 07:10 PM   #5
Texas is having unusually cold weather this winter! Earth, TX is up north near Amarillo isn't it? Y'all seem to have colder winters than we do in San Antonio and Austin. Luckily I haven't had any pipes burst, but I think I'll be insulating them just in case. I'd rather be prepared for the next bout of weird weather than deal with water leaks.
MsMatthews is offline   Reply With Quote
Old 02-11-2011, 08:24 AM   #6
Household Handyman
Rewards Points: 1,408
All the insulation you wish to add will NOT stop pipes from freezing IF the cold temps sustain and gets through the insulation. As noted, some form of hear needs to be applied in this area. It will not require heating as in the living area of a home, just enough to keep this area above the freezing level. That's why the light bulb trick works, and I have used it here in S. GA. within my well-pump house in unusual weather. I also now use heat lamp in my work trailer overnight to keep things from freezing. Very hard to use caulk the day after temps hit in the mid-20's overnight.
insulating pex pipes ibs325 Plumbing 28 03-29-2012 03:59 PM
What are the major benefits of insulating the refridgerant pipes mobiledynamics HVAC 3 08-03-2010 11:05 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
worth insulating pipes? wombosi HVAC 4 02-15-2009 06:32 PM
Insulating Steam Pipes Densec General DIY Discussions 5 01-04-2009 09:14 PM
