Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-07-2007, 11:29 AM   #1
Lady DIYer
SagittarianLady's Avatar
Question
Insulating metal window frames
1952 brick home with metal frames
What can I do to insulate my hollow metal window frames?
Thanks!
SagittarianLady is offline   Reply With Quote
Old 11-07-2007, 05:06 PM   #2
We had a 1938 house with metal casement frames. The previous owners installed interior wood framed storms you screwed into the metal frame. After a few winters I removed the whole mess and installed Andersen double hungs.
Ron
Old 11-07-2007, 05:56 PM   #3
The wooden storm is a good idea. There is no good way to insulate them. As you know, metal is thermally conductive and you will lose heat out them regardless of whether they are insulated or not.
Drilling holes in the frames and injecting door and window foam is the only idea I would have, but then you'd need to figure out how to cover up all those holes.
Replacing the windows is a better idea.
XSleeper is offline   Reply With Quote
Old 11-07-2007, 07:10 PM   #4
Replace them
Amber is offline   Reply With Quote
Old 12-06-2007, 03:18 PM   #5
Originally Posted by Amber View Post
Replace them
What if you can't replace them? I rent an apartment with metal windows. Any suggestions besides buying expensive lined curtains?
Thanks!
Jane0218 is offline   Reply With Quote
Old 12-07-2007, 10:37 PM   #6
For a less expensive temporary solution, try 3M window insulator kits.
Old 12-08-2007, 10:36 AM   #7
Thanks for the suggestion. I'm also going to look into using magnetic tape around the window and then use something (but I don't know what) that's heavier/thicker than the window insulation kit plastic, but still clear.
Insulating Aluminum Window Frames waynerlee Windows and Doors 25 04-26-2012 12:13 PM
Metal Shed Insulating Zen_Dog General Discussion 10 08-22-2008 10:30 AM
Condensation on Metal Window Frames: Should I Caulk? xquercus General Discussion 6 06-29-2007 10:24 AM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
