Insulating Inaccessable Area - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 03:56 PM   #1
Do work
Rewards Points: 81
Insulating inaccessable area
Thanks in advance for all your replies.
So I just finished adding another layer of R30 roll insulation to my attic and I've noticed the difference already. Its a lot warmer in my house.
But while in my attic I did notice an uninsulated area above my 2 closets that are on either side of my front door. The problem is the house is 2 stories and the closets are on the first floor. I can see that there is no insulation on the ceiling of the closet and if I go into the closet the ceiling feels really cold.
So my question is this. I have 1 roll of R30 insulation left over. Do I cut that up and drop the insulation down from the attic to the first floor and hopefully cover the entire area or should I look at another options? Maybe use blow in insulation?
The area above each closet is like 2.5 feet by 3 feet and I only have access from the attic which is a 15 foot drop from attic to ceiling.
Thoughts?
liquidvw is offline   Reply With Quote
Old 01-11-2010, 05:15 PM   #2
jlhaslip's Avatar
Rewards Points: 1,564
might work and I can't see it hurting anything.
cut it into fist size pieces and 'filler up' until you get a decent layer in there.
of course, there is likely no heat in the closet, so that might be part of why it would be cold.
jlhaslip is online now   Reply With Quote
Old 01-18-2010, 01:36 PM   #3
Do work
Rewards Points: 81
Thank you. I took your advice, I used all the leftover insulation and cut them up and dropped them down. The closet is warmer now for whatever its worth. thanks again.
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating rim joists in old house topgun Building & Construction 4 02-22-2009 06:40 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
