Insulating Fireplace Hearth - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 10:18 AM   #1
Insulating Fireplace hearth
My neighbor has a large fireplace hearth made of marble that sits up high. It's a hollow box approximately 1 1/2 tall, 1 1/2 ft deep, and approx. 3 ft wide. It sits above a crawl space. The marble in constantly cold in the winter. They would love to insulate but removing the marble could damage it. We discussed going into the crawl space and drilling a hole under the floor and spraying foam insulation. I'm concerned it could be a potential fire hazard. Any suggestions?
Red Truck is offline   Reply With Quote
Old 02-07-2010, 02:12 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Marble is cold. I have a small slab of marble I use as a table top. It always feels cold to the touch no matter where the thermostat is set.
Before tearing stuff up I would find out if the marble is significantly colder than it should be. Many marble finishers have small scraps they will give you as samples. Cheap and easy test: Leave a scrap sitting on it for 24 hours and then see if you can feel a difference in the temps.
Fireplace hearth zulusue Building & Construction 1 01-24-2010 11:00 AM
Fireplace facelife - needing hearth advice louiejr Building & Construction 4 11-25-2009 06:57 AM
Framing, insulating around fireplace rough-in billthecat Building & Construction 3 10-08-2008 07:34 PM
Please Help with Fireplace Hearth Planning BobnSofi Building & Construction 1 02-18-2008 07:26 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
