Insulating Exposed Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-07-2007, 12:05 PM   #1
Hi All,
I recently purchased a home (built in 1928, located in the northeast US) that has a side entrace foyer converted into a bathroom. The house is on a hill and the floor of the bathroom stands 8 feet or so off the ground (bare dirt) and is completely uninsulated. The area below the floor is open to the outside and used as outdoor storage space (it is walled on 3 sides). I am a complete newbie and have found some information on the web, but much of it is conflicting or not completely applicable to my situation. My question is, what would be the best way to insulate the floor of this bathroom? Thanks in advance.
-batou
batou is offline   Reply With Quote
Old 12-07-2007, 02:12 PM   #2
Use fiberglass batts between the floor joists, placing the kraft paper up against the floor. R-19 is probably the right thickness for that application. Then cover it up with something like OSB or plywood to hold it in place, and keep the wind out of the insulation.
NateHanson is offline   Reply With Quote
Old 12-08-2007, 10:04 PM   #3
Mod / ArchiBuilder
Cole's Avatar
The kraft faced side will always face the warm side of the building.
I agree also with the above poster about the OSB /Plywood!
Cole is offline   Reply With Quote
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
insulating under first floor NateHanson Building & Construction 19 11-30-2007 10:09 AM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 01:07 PM
