Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-31-2009, 10:04 PM   #1
Default insulating basment windows
I have those single pane rectangular windows in our basement. They pivot open using the simple handle - ie the cheap ones.
So how do I stop the heat loss with them, without blocking the light or making them difficult to open...?
pmatc is offline   Reply With Quote
Old 11-01-2009, 08:27 AM   #2
If you are talking about the steel framed variety, or old wood single glazed windows, replace them with new double insulated vinyl windows.
Old 11-01-2009, 11:05 AM   #3
pmatc,
I have those same windows in my 1957 home. I wasn't in the market for replacing them so I build storm windows for each of them which fit snuggly into the window recess on the inside.
It was an easy and inexpensive solution that helped considerably with heat loss! The hardest part was making the (out of square) frame.
roxksears is offline   Reply With Quote
Old 11-03-2009, 07:08 PM   #4
Are yours the "hopper" windows that pivot at the bottom ? The steel frames on mine were embedded in the concrete wall. They leaked air something terrible.
I looked at replacing them, but "good" windows were rather pricey, and the install didn't look at all like fun.
So I welded up some frames out of 3/4 x 3/4 x 1/8 angle iron for each window. Painted them white gloss. I mounted them to the inside wall with acrylic caulking ( continuous heavy bead - all around ) Each frame was actually a "tap" fit in the window hole, so they are solidly installed. I made removable "windows" out of 3/16" acrylic. I put a strip of self adhesive flexible magnetic strip on the perimeter of the the acrylic to hold the acrylic window onto the steel frame. ( you can get the flexible magnetic strip at the big box stores, but the strength is rather low - I got a roll from Bunting Magnetics - online. Get the most powerful strip. The pull forces listed on their website can maybe be attained in a laboratory, in real life, the pull force is much lower). A couple of handles on the acrylic window helps to quickly pull it on and off, and a couple of small tabs welded to the bottom of the angle iron frame ensure that the acrylic window does not slowly migrate downward.
In an unfinished basement, they actually look pretty good. They go up in the fall and come off in the spring. Hardest part for me was the welding the angle iron frames --- the miter joints have to be very flat so that I had a good seal with the magnetic strip.
SPS-1 is offline   Reply With Quote
Old 11-03-2009, 07:20 PM   #5
Default windows
so why dont i just cut some 1/4" acrylic and glue a projection on the front for a handle - push into opening, take off in spring
More On This Topic
Hi I'm Mike Rogers and we are making this video for expertvillage.com on the use of mig welder. Next job that we are tackling is a creation of a right angle joint between two bits of steel. Now one easy way to create the joint to start off with is just... Read More »
Replacing your windows is one way to boost the value of your home, especially if the new windows are more energy efficient. One of the popular styles of replacement windows is vinyl retrofit replacement windows. Read this eHow to learn how to trim... Read More »
When you're out ice fishing for a couple of days you will probably get hungry for a hot meal. You don't want to build a campfire out on the ice though for obvious reasons. Follow these steps to build an ice fishing stove to stay afloat of your hunger... Read More »
My name is Courtney Hester on behalf of Expert Village and in this clip we're going to be making a single fridge magnet. The first thing we're going to do is take our spring henge clothespin and we need to paint it. I'm going to paint this one red and... Read More »
Today we're changing a rear latch, on a ninety-six Ford Explorer. In this step, I'm going to demonstrate the proper procedure for unbolting your latch and removing it, from the door assembly. I have my three eights ratchet with an eight millimeter socket... Read More »
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 02:18 PM
insulating windows amakarevic Building & Construction 11 01-29-2008 10:07 PM
Insulating basement windows Keyo77 General Discussion 3 01-06-2008 08:33 PM
Insulating under extruded windows rookie50 Building & Construction 2 12-07-2006 07:54 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 08:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
