Insulated Wood Burning Stove Pipe - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 09:25 PM   #1
insulated wood burning stove pipe
I have removed a wood burning stove from my house, and now I want to cut off flush the protruding insulated chimney pipe that is sticking through my wall. I want to cap it off, and mount my big screen tv over the hole. Is the insulated chimney pipe safe to cut off? Is the insulation safe? What should I use to cut?
dellison7 is offline   Reply With Quote
Old 03-10-2011, 10:47 PM   #2
Rewards Points: 5,336
How old is the installation? What sort of insulation is in the pipe?
You can contact the company who made it and ask them or you can post a photo and maybe we can identify it.
If it's safe to cut, you can use a grinder with a metal cutting composite blade to cut it off. They sell caps you can use to seal the pipe after you insulate it.
Ron
Old 03-11-2011, 06:09 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... I'd think it would make more sense to completely Remove the pipe, 'n rebuild/ reinsulate the wall...
Bondo is online now   Reply With Quote
Old 03-11-2011, 07:14 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Sorry.....couldn't resist......
tcleve4911 is offline   Reply With Quote
Old 03-11-2011, 03:27 PM   #5
If it's a modern stainless steel insulated "through wall" thimble, you want to remove it. Should be easy. If you can get it all taken apart without damaging it, you can sell it. Those components are expensive.
pyper is offline   Reply With Quote
Old 03-14-2011, 12:48 PM   #6
Rewards Points: 398
http://www.selkirkcorp.com/metalbest/
One brand, there are others
fireguy is offline   Reply With Quote
Wood Burning Stove Pipe Question jh756 HVAC 1 08-20-2010 02:19 PM
Wood Stove Blower question Alan HVAC 6 11-27-2009 09:49 PM
Wood Stove in Basement? dwolek HVAC 4 10-28-2009 08:02 AM
Building a base for my wood stove Verbose Building & Construction 1 10-11-2009 07:06 PM
Home made wood burning furnace JustinK HVAC 14 10-05-2009 08:26 PM
