-   -   insulated wood burning stove pipe (http://www.diychatroom.com/f2/insulated-wood-burning-stove-pipe-97984/)
dellison7 03-10-2011 10:25 PM
I have removed a wood burning stove from my house, and now I want to cut off flush the protruding insulated chimney pipe that is sticking through my wall. I want to cap it off, and mount my big screen tv over the hole. Is the insulated chimney pipe safe to cut off? Is the insulation safe? What should I use to cut?
Ron6519 03-10-2011 11:47 PM
How old is the installation? What sort of insulation is in the pipe?
You can contact the company who made it and ask them or you can post a photo and maybe we can identify it.
If it's safe to cut, you can use a grinder with a metal cutting composite blade to cut it off. They sell caps you can use to seal the pipe after you insulate it.
Ron
Bondo 03-11-2011 07:09 AM
Ayuh,... I'd think it would make more sense to completely Remove the pipe, 'n rebuild/ reinsulate the wall...
tcleve4911 03-11-2011 08:14 AM
Sorry.....couldn't resist......
http://t2.gstatic.com/images?q=tbn:A...lMpXYV25dsMHEQ
pyper 03-11-2011 04:27 PM
If it's a modern stainless steel insulated "through wall" thimble, you want to remove it. Should be easy. If you can get it all taken apart without damaging it, you can sell it. Those components are expensive.
fireguy 03-14-2011 01:48 PM
http://www.selkirkcorp.com/metalbest/
One brand, there are others
