Installing Vinyl Siding On Dormers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 09:57 PM   #1
Rewards Points: 150
installing vinyl siding on dormers
Hi all, I am new but looks like great site. We just tore the old wood siding off our dormers when we had the roof replaced. We went down to studs and re-sheeted them with 7/16osb covering that with typar house wrap. We used weatherguard (ice) both on the roof and up the walls about a foot and then step flashing which also laps up the walls about 2", My question is, we are planning to install vinyl siding this week and we were wondering how do you put on the J-channel for the siding to sit into up the roof without nailing into and tearing up the weatherguard and step-flashing?
guest is offline   Reply With Quote
Old 10-24-2010, 09:48 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
the j is supposed to be held up off the rake about an inch
Tom Struble is offline   Reply With Quote
Old 10-24-2010, 05:41 PM   #3
Agreed, keep the J up one inch from the roof. Typically the ice and water membranes are self sealing to the nails so you should be fine.
Brimar is offline   Reply With Quote
Old 10-25-2010, 11:00 AM   #4
Rewards Points: 150
thanks a lot!!! I will make sure they do that.
Old 10-25-2010, 12:12 PM   #5
Registered User
Rewards Points: 526
Just to mention, be sure to tape the Typar seams and laps for a Water Resistant Barrier. The vinyl will let water through the locking seams and especially at the "J" channel. http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
You definitely don't want any water getting to the osb because it will slowly breakdown. Even tape the bottom edge of the H.W. behind the "J" channel, you need to completely protect the sheathing. http://sidingmaster.com/documents/Ne...ngmoisture.pdf
Keep it dry! And, welcome to the forums!
Gary
Old 10-26-2010, 12:16 PM   #6
Rewards Points: 150
another good tip! thanks again!
Installing Vinyl siding rob_acdgsdetc Building & Construction 3 07-31-2010 04:24 PM
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 12:58 AM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 10:13 AM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 12:17 AM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
