Installing Segal Deadbolt Lock - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-02-2014, 06:53 PM   #1
Rewards Points: 16
Installing Segal deadbolt lock
I am trying to install a Segal jimmy-proof deadbolt lock, per the instructions here: http://www.segallock.com/installation.shtml. The individual parts all seem to work just fine, but once I actually mount the lock on the door, I am unable to lock it with the key. Does anyone have any experience with these locks?
Specifically: The cylinder turns just fine with the key. Off the door, I can lock and unlock the deadbolt just fine using a screwdriver.
On the door, I can lock and unlock the deadbolt using the knob. I can unlock the deadbolt by turning the key counterclockwise. When I turn the key clockwise, however, it stops before the bolts are fully engaged, so I can't lock the lock.
As far as I know, I have followed the installation instructions to the letter, including cutting the cylinder tailpiece to the correct length: The door is 1-11/16" thick. Per the chart in the instructions, this falls between break points A and B. I have tried A, B, and manually cutting the tailpiece halfway in between. None of these works.
Any ideas?
traghel is offline   Reply With Quote
Old 01-02-2014, 09:21 PM   #2
Rewards Points: 3,282
The bar that goes through the door which connects the key section on the outside of the door to the lock on the inside. You have it turned the wrong way. There is some free play clockwise-counterclockwise in the bar. Pull it out and turn the bar the other way then put it back in.
Bob Sanders is offline   Reply With Quote
Old 01-03-2014, 10:32 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
The timing is off. take the key out of the lock cylinder. Remove the lock case. Take a screwdriver and turn the slotted hub in the back all the way to the left until it stops. Then mount the lock back on the door. The key should now be able to turn a full 360.
Outside door lock stuck teamcampreder Automotive Repairs 11 07-24-2012 07:19 AM
key in the lock on the inside and now can't open from outside kwisj Windows and Doors 1 05-18-2012 07:37 AM
installing door lock, door won't latch Sueflammer Windows and Doors 2 06-24-2011 06:31 AM
Installing simple lock on a hollow metal door? heartj00 Building & Construction 10 11-29-2010 12:17 AM
