Installing Racks In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 04:39 PM   #1
Installing racks in garage
hello. I have a few problems and hope that you can help.
1. My garage is small and appears to be cinder block built. If I want to put shelves up, what what I use to secure the shelves to the cement or cinder block so that they do not fall. What tools would i need?
2. The roof is pitched and if I wanted to attach a systems to the beams that would hang down and allow me to put up multiple shelves, what would be a brand name that I should look for?
Sorry if I seem completely clueless, not very good as a handyman but trying. Thanks in advance for your help and advice.
p3ter is offline   Reply With Quote
Old 06-13-2009, 04:49 PM   #2
What size are the beams you want to suspend shelves from?
How far apart are they? 16" OC, 24" OC ?
Are these joists spanning the garage?
How big is the garage?
What will you be storing on the shelves (weight) ?
Any pics of the area?
Old 06-13-2009, 06:00 PM   #3
The beams appears to be 2 x 4.
They are 24"" OC.
I do not believe there are joist spanning the garage.
the garage is 20 long by 11 wide.
I would think less than 100 lbs per self.
having troubling uploading pic's
Old 06-13-2009, 06:29 PM   #4
Are the roof rafters also 2x4?
It sounds like you have trusses
Which are not really made for additional load
An engineer woudl be needed to calculate loads & what you could add
Possibly you could add some 2x8's to span the 11' to add shelving
Old 06-13-2009, 09:10 PM   #5
Garage Shelves - Pic's included
Name:  garage 00000.JPG
Size:  18.6 KBName:  garage 00001.JPG
Size:  19.6 KBName:  garage 00002.JPG
Size:  19.0 KBName:  garage 00003.JPG
Name:  garage 00004.JPG
Name:  garage 00005.JPG
Old 06-13-2009, 09:31 PM   #6
Are you looking to leave enough room for a car?
I'd run joists across the back 4-8' every 16" & put 1/2 plkywood up there for storage
In the back I'd build wall to wall shelving in the back 4'
I'd make it basically free standing
Maybe use the new joists up top as support (from tipping over)
And maybe a brace on each end for the same thing
Old 06-13-2009, 09:52 PM   #7
garage
Thank you very much. We have never been able to put car in so that will not change.Thanks again.
Old 06-15-2009, 12:41 PM   #8
Sleeve Anchor
I would anchor some 2 x 4's to the block using some sleeve anchors. www.sleeve-type-anchor.com I would also support your shelve with 2 x 4 legs that simply rest on the concrete ground. There is a installation video on the site that I have provided.
Bronx is offline   Reply With Quote
Tags
garage storage , pitched ceiling in garage
Installing a Ceiling in a Garage oldbuffer Building & Construction 8 06-09-2009 09:00 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Installing service to my garage. WFKnight Electrical 4 02-27-2009 10:18 AM
Some questions about installing new garage door on old opener and other stuff Skeletor916 General DIY Discussions 2 01-23-2009 04:51 PM
Installing an attic above my 2 car garage jdavid Carpentry 2 07-17-2008 11:50 AM
