Installing Pocket Doors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-16-2013, 03:00 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
There have been a couple of threads asking about pocket door hardware.
I bought the hardware for one awhile back....like 1.5 years back.....and I'm just now getting around to installing it...
I bought the Johnson Hardware kit off Amazon. I think I paid like $90 for the kit. It can be 'adjusted' for different door widths. The 'adjustment' requires you to make a couple of cuts....no big deal if you have a sawzall...
Ok...time for some pics....
The kit comes with 4 'studs'....since I already had a wall on one side, I only had to use two of them.
One very important point....your doorway has to be plumb and square. The kit as enough adjustment in it to help out.
I would suggest downloading the install instructions if you want more info.
On a side note....I have another kit that I am 'really' making some mods to...it's for my oldest son's closet. I'm making it into a split pocket door. My son and I are going to make up a gear system so they both open a the same time....sort of like the doors on the USS Enterprise.
Old 06-16-2013, 06:43 AM   #2
DIY staff
Rewards Points: 7,174
Ddawg---I usually fill in the spaces between the 'studs' with 3/4" plywood.
Pocked doors are used on bathrooms frequently---and towel bars and such must be mounted on those 'walls'---anchors are to deep and will hit the door.
Having a solid plywood backing allows you to use the appropriate length screws ---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (06-16-2013), ddawg16 (06-16-2013)
Old 06-16-2013, 10:11 AM   #3
JOATMON
ddawg16's Avatar
Good point Mike....but in this case, it's going to have a dryer next to it....no towel rack...or anything else of any significant weight.
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (06-16-2013)
Old 06-16-2013, 11:04 AM   #4
Rewards Points: 3,130
I used that same kit. Every interior door in our log house (seven of them) is a pocket door. My wife designed the house and that's what she wanted.
Old 06-16-2013, 04:31 PM   #5
DIY staff
Pocket doors,properly done, with good hardware are a fine addition to a home--sometimes the best or only way to close an opening---
Old 06-16-2013, 05:35 PM   #6
Framing Contractor
Rewards Points: 126
I like to use screws where that meets the floor. I have used nails in the past, but I found that sometimes it causes a squeak when someone walks by.
sixeightten is offline   Reply With Quote
Old 06-16-2013, 06:12 PM   #7
JOATMON
ddawg16's Avatar
Mine are screwed. When ever possible I prefer screwing to nailing.
sixeightten (06-16-2013)
Old 06-18-2013, 01:14 AM   #8
Although the hardware can work on any type of door — solid or hollow core or flat or paneled — it’s a good idea to buy a pocket door hardware system that includes the door. For a bathroom, consider a door with a mirror on one or both sides, which is a convenient and useful choice.
woodlandpatio is offline   Reply With Quote
Pocket doors, how do they connect to the floor? KarlJay Remodeling 19 12-23-2012 11:50 AM
space saving with pocket doors deana Remodeling 13 03-16-2012 12:23 PM
installing bifold doors with baseboard molding cuda719 Carpentry 1 07-04-2011 08:15 PM
100 year old pocket doors valeriephillips Building & Construction 1 03-28-2011 11:44 PM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 12:35 PM
