Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-24-2010, 12:46 AM   #1
Installing non pre-hung doors
So here is my problem:
My wife and I bought our house several years ago and in our bed room our closet had two bifold sliding doors. She hates them and has been my case to replace for years.
I went to Lowes today and bought two slab doors that will fit, but here is my question. Is there an easy to figure out how far in I need to mortise out my hinge on the door frame. Obviously there is no mortise there at the moment. I obviously want my doors to be square and not stick out, just not sure how to make that happen.
I know there is probably a way. I have a router and all the necessary tools to make it happen, just looking for an easy way to do it. Thanks so much.
littlehurt98 is offline   Reply With Quote
Old 09-24-2010, 07:01 AM   #2
You said, "bifold sliding doors", which is it??? Sliding(bypass) doors are usually in an opening that is about 1" less than bifold doors. That is a big difference when you try to install hinged doors. That requires cutting down the doors or modifying the opening, cutting the doors is the usual option.
As to the how, look at the hinged doors around the house. That will give you an idea of what goes where.
Old 09-24-2010, 09:22 AM   #3
Well here are a couple of door and jamb hinge template kits
http://www.coastaltool.com/a/accessories/door_acc.htm
http://www.coastaltool.com/a/port/59381.htm
http://www.coastaltool.com/bosch/83038.htm
epson is offline   Reply With Quote
Old 09-24-2010, 03:07 PM   #4
Tizzer's Avatar
Won't the OP have to frame/rock & trim a small wall in the middle of that door opening so those doors will stop & latch? Probably means cutting the doors.
Tizzer is offline   Reply With Quote
Old 09-24-2010, 05:51 PM   #5
firehawkmph's Avatar
Not if they plan on using ball catches on the top edge of each door. The doors will close like french doors, with just a slight (1/8") gap between them. The knob on each door should be a dummy knob.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Pre hung doors vs hanging doors myself Windows Remodeling 6 04-09-2010 03:20 PM
Thanks to my wife, installing a set of French Doors BJLower Remodeling 4 04-04-2010 09:07 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Masonite pre hung doors sticking hot weather Pawl Carpentry 4 07-08-2008 05:26 PM
