Installing A Lentel - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 11:48 AM   #1
installing a lentel
I want to know how to keep the bricks from sagging that are on the outside wall above the area where the lentel will go.
Helerick is offline   Reply With Quote
Old 02-21-2010, 04:23 PM   #2
Rewards Points: 5,336
Why don't you specify exactly what you want to do so the advice given is appropriate.
Ron
Old 02-21-2010, 04:39 PM   #3
Rewards Points: 582
Have you also got a photo of where you wish to install the lintel.
stuart45 is offline   Reply With Quote
Old 02-21-2010, 08:32 PM   #4
remodeling pro
Not really sure what you are asking either. The purpose of the lintel is to support the bricks above it. Maybe you can clarify the situation for us.
Are you trying to retrofit a new opening into an existing wall, and wondering how to deal with the bricks until the new lintel is installed?
troubleseeker is offline   Reply With Quote
Old 02-22-2010, 06:06 AM   #5
Installing A lentel in an existing basement wall
I am trying to retrofit a new opening into an existing wall, and wondering how to deal with the bricks until the new lintel is installed?
I am concerned that when I make the opening the bricks will move before I have a chance to install the lentel.
Old 02-22-2010, 07:03 AM   #6
Rewards Points: 1,232
Install the lintel first, then remove the brick.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 02-22-2010, 12:49 PM   #7
I want to put a window in the foundation wall where there was no window. How do I make a hole to install the lentel without the bricks above it coming down?installing a lentel-2010-02-13-003.jpg
Old 02-22-2010, 01:14 PM   #8
On the inside, you make the saw cut for the top of the window, install the lintel, then finish cutting out for the window.
Old 02-22-2010, 01:42 PM   #9
The problem with the basement window is that the sill plate and rim joist block access to the location. In this situation, I would cut the slot in the bricks from the exterior, all the way through the bricks and slide the lintel(or just a flat metal bar) in under the brick. Cut out the window opening in the foundation. Take a lintel and work it in from the window opening to it's proper location. You might need to widen the opening at the top to get it into the space. Once it's in place, mortar any extra gaps.
Derust, prime and paint the lintel before you install it.
This scenario will work for a window 36" and under.
Ron
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 06:24 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
