Installing A Double Door In A 48" Opening - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2009, 03:43 PM   #1
Rewards Points: 81
installing a double door in a 48" opening
Hi, i have an interior opening of about 47 1/8" with the frame, and 48 3/4" taking the frame out. There used to be 2 slider doors there. This would be a door going into our master bedroom. The guy that was doing work suggested a 48" double door for this opening, but i don't know. Is this a good spot for a double door or should i go with a big single? There is sheetrock on both sides.
mayhem69 is offline   Reply With Quote
Old 12-30-2009, 05:48 PM   #2
Rewards Points: 5,336
Don't see why you would need a 48" door getting into a bedroom unless it's just for the look. You could just frame out for a 36" door in the current opening.
Ron
Old 12-30-2009, 05:51 PM   #3
Rewards Points: 81
Hi Ron, that's what i finally realized. Our young remodeler had the bright idea of putting double doors in the existing frame. Don't think that would look too good. Thanks for your help.
Old 12-30-2009, 05:56 PM   #4
You would need a minimum of 50" for a 48" door opening.
Ron
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
installing a door into an opening where there wasnt a door before gregdonovan Carpentry 16 06-20-2009 12:58 PM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 12:35 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Expanding Opening & Installing New Header KazzyK Remodeling 4 12-28-2008 10:39 PM
