Installing Door Jamb For Sliding Surface Mount Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 11:57 AM   #1
Rewards Points: 32
Installing door jamb for sliding surface mount door
I plan to replace a hinged door and frame with surface mount sliding door hardware. The current hinged door was added about 3 years ago as a temp conversion to a bedroom. The opening was not sized for a door so it is about 84" in height and accommodated a 36" door frame.
I need to install the door jamb for the new sliding door. I think I have an idea how to build the jamb. I want a stop for the door when it is closed so I know I have to extend the jamb on that side of the opening into the room.
Can anyone recommend a book or PDF instructions (doesn't have to be free) that shows how to design door jambs for sliding surface mount doors?
Ed
edspyhill09 is offline   Reply With Quote
Old 06-24-2013, 06:06 AM   #2
DIY staff
Rewards Points: 7,174
Adding jambs to an opening is simple enough---look at instructions for hanging a prehung door--
-buy or make the jambs--
-check the floor for level--
-adjust the jamb side lengths if the floor is out of level--
-glue and nail the head(top) jamb to the sides--
-put it in place and shim and nail---
oh'mike is online now   Reply With Quote
Old 06-24-2013, 07:02 AM   #3
Rewards Points: 32
Thank you. I realized I could also use the instructions for installing molding and "jambs" on a passageway between rooms.
Now onto buying the surface mount sliding door hardware and a door.
Ed
The Following User Says Thank You to edspyhill09 For This Useful Post:
oh'mike (06-30-2013)
Can you mount a storm or screen door on this front door? daluu Windows and Doors 15 12-26-2012 04:55 PM
is it possible to mount screen door on this? vote4Pedro Windows and Doors 3 12-26-2012 01:55 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Installing pre-hung door over tile to laminate transition aldgagnon Carpentry 5 10-26-2010 06:37 PM
