Installing Curtain Rod Without Drilling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 09:26 PM   #1
Installing curtain rod without drilling
Hi, wondering if anyone can help with this problem i have
Is it in anyway possible to install a curtain set (rod, the thing holding the rod, the curtain etc etc) without drilling the wall above the window ?
The window frame is made of hard plastic btw, is there some way to mount the rod using the frame ?
Thanks for any reply, its a weird request I know
djay17 is offline   Reply With Quote
Old 12-02-2012, 10:17 PM   #2
Rewards Points: 2,212
There are tension rods that fit between the frame and spring out and hold in place
https://www.google.ca/search?q=curta...E8mziwKKqoDgBA
another way is to use stick on hooks
mae-ling is offline   Reply With Quote
Old 12-03-2012, 10:57 AM   #3
Tension rod similar to your bathroom curtain rod. Available in different lengths and colors
iGeek is offline   Reply With Quote
Old 12-08-2012, 01:54 AM   #4
Hi, thanks for the suggestion on using tension rods, however i don't think it will be feasible as the walls parallel to the window frame are not flat surfaces, also the window have a frame which have verticle and horizontal "rods" giving the window a grill look, you cant jump oit of the window.
Old 12-08-2012, 09:12 PM   #5
3m makes stick on hooks of all sorts, some you can even unstick ad not wreck the paint.
Old 12-26-2012, 08:01 PM   #6
Pics and how to edit post
How do you edit the original post ?
Anyway here are the pictures of the window frame I mention in the original post
Old 12-26-2012, 08:41 PM   #7
Rewards Points: 558
If you want it removable you can use heavy duty Velcro strips.
epson is offline   Reply With Quote
Old 12-27-2012, 12:02 AM   #8
Ruales Building Service
Suction cups and adhesive area unit ne'er appropriate for curtains of any kind, even light-weight ones. It's potential to use a hammer and nail to create pilot holes, however reckoning on precisely what you have got happening there in terms of wall end, age of the wood you are golf stroke the outlet in, however deep your pilot hole should be, you may do some hard-to-fix injury with a hammer and a nail, or it'd simply not work on all for numerous reasons. A drill very is that the correct tool to try and do what you would like to try and do, and victimization the right tool is that the smartest thing to try and do.
rualesbuilding is offline   Reply With Quote
Old 12-27-2012, 12:11 AM   #9
Deck Staining Pro
bigchaz's Avatar
Huh??
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Installing blinds in apartment mdo11 General DIY Discussions 6 12-30-2012 08:35 AM
Installing shower unit inside bathtub mlinpdx Plumbing 2 11-29-2012 12:03 PM
Installing ceiling fan from scratch feel Electrical 20 04-12-2012 09:04 AM
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 02:21 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
