Installing Bar Nosing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 12:58 PM   #1
Hello All,
I have a quick question. If the nosing of the bar looks like the picture below would the bar counter top slide into the 2 15/16" flat piece and I would add a 1 1/2" piece of wood on top, or does the bar counter slide into the 5/8" flat piece then I add a perpendicular piece of wood to sit under the lower flat part. Please Help.
lucasc79 is offline   Reply With Quote
Old 01-02-2011, 07:48 AM   #2
Rewards Points: 27
Originally Posted by lucasc79 View Post
Hello All,
I would think that would be a personal preference. Do you want a 1.5" lip at the bar to help with sliding drinks around or would you rather have a more flush finish with the molding? I think it can be installed either way.
MBatson is offline   Reply With Quote
Old 01-02-2011, 08:59 AM   #3
I don't like ANY lip around a table surface. I find that it tends to collect dirt and grime. On the other hand, it might contain a spill.
Given these preferences, and given your two choices, I think I would tend to minimize the lip, installing the profile on the 5/8" surface.
oberkc is offline   Reply With Quote
Old 01-02-2011, 11:31 AM   #4
Carpenter
dtsman's Avatar
Bar tops are usually doubled-up 3/4. that is what sets into the 1-1/2" notch. Then the substrate it sets on goes into the larger lip to strengthen it. If no substrate, then you screw and glue and added piece to the underside of the finished bar top to support the trim nose.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-02-2011, 08:55 PM   #5
thanks, this makes the counter much easier to build.
Old 01-02-2011, 09:41 PM   #6
Here's a pic showing a lip
The 3/4" hardwood flooring I bought is 1/4" taller than the nosing endeavour Flooring 1 12-03-2010 06:42 AM
ceramic tile stairs with wood nosing karenk Flooring 0 03-17-2010 10:30 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
