Installation Of Bathroom Exhaust Fan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2014, 10:24 AM   #1
Installation of bathroom exhaust fan
I am in the process of installing a bathroom exhaust fan in my 2nd floor of a 3 story home. There are two wiring connections (one for a light and one for the fan). I only need the one for the fan. Am I able to just put screws covers on the black, white and grounding wires and tape them with electrical tape and leave them up above the fan within the ceiling cavity and wood above (3rd floor). Please advise as I want to be sure it is safe to do?
Thanks,
Andrew
drew242424 is offline   Reply With Quote
Old 01-13-2014, 10:47 AM   #2
Rewards Points: 5,974
Thanks,
Andrew
By screw covers I'm assuming you are referring to wire nuts. The fans I have put up have a little compartment to put the wire nuts and connections in.
Old 01-13-2014, 11:35 AM   #3
Yes I meant wire nuts. The fan has a compartment to put the wires. The problem is the wire for the fan is longer in length than the wire for the light. In addition, the fan can only be placed in the cavity of the ceiling two ways. The one way will not allow the light wires to reach the compartment within the fan. If I place the fan the other way the wires will reach but the exhaust will not reach. What do you think?
Old 01-13-2014, 12:19 PM   #4
Rewards Points: 1,294
You will need to make the connection in an approved junction box, either inside the fan or by adding another box with cover and adding romex (conduit if required) between the box and fan housing
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
drew242424 (01-13-2014)
Old 01-13-2014, 12:42 PM   #5
What if I extend the length of the exhaust hose?
Old 01-13-2014, 01:14 PM   #6
Rewards Points: 6,652
How far are you planning on extending the hose? If only needing a fan, you may want to look at one of the remote blower units, vs a standard Nutron Fart fan.
This is what I am talking about http://www.pureairproducts.com/remot...ebathroomfans/
Old 01-13-2014, 02:37 PM   #7
Not sure how that would help with a wiring issue.
Old 01-13-2014, 03:55 PM   #8
In a little over my head
Rewards Points: 706
As stated, the loose connections need to be in a box. And the box has to be accessible. So you could install a box in the ceiling, one joist over and pull the wires into that, put a blank cover on it, on the ceiling. Not sure about the WAF on that one, though. If you extend the hose, and put a u-turn in it, I'd be afraid of lost efficiency and condensation.
Is there any way to get the unused wires up to suitable location for a box accessible from the third floor? That could be fun, having a switch in the 2nd floor head, controlling a lamp upstairs. ;^)
ratherbefishing is offline   Reply With Quote
Tags
bathroom , electrical , fan , wiring
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
Can bathroom exhaust and dryer share same outside duct? benze HVAC 17 09-08-2010 02:24 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 04:15 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
