Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-29-2008, 08:19 PM   #1
Install storm doors ourselves, or pay to have it done?
We want storm doors on our front door and side door, before winter!
We understand storm doors can be tricky to get right. Feeling courageous enough to ask:
Can we get good advice and do it ourselves, to avoid installation fees? How smart do we need to be to install our own storm doors?
Every dollar that we save means we can get better quality materials put into the repairs of this house! That's why we're so motivated to try to do as much ourselves as possible!
Beth777 is offline   Reply With Quote
Old 08-29-2008, 08:24 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is it a DIY job?...sure, it can be.
If you have the time, plan on taking possibly the better part of a day, to pick up and install a storm door (i.e. Anderson). The time to measure it out, read all the directions, sort thru all the parts, cut the side frame down, drill and install all parts, etc...
If you want to put two on your house, you could attempt to do the first one. If it ends up being a nightmare, have the second one installed by a pro.
Good luck.
- Build Well -
Old 08-29-2008, 08:31 PM   #3
Moderator
Termite's Avatar
Agreed, it can definately be a DIY job.
When I did my first one, I was shocked at what a task it actually is. I was frustrated because I've hung a lot of doors and am good at it, but never a storm door until then. It sounds easy until all the parts and pieces are laying there in front of you. Like Atlantic said, plan on a few hours of work at least.
Old 08-29-2008, 09:31 PM   #4
Okay. So it might be possible for us to do ourselves, but not as a rush job! Maybe we'll study the instructions before we decide if we're up to the task!
A couple more questions:
Is any one brand easier to install than another? Better directions, better-fitting parts, or all pretty much the same?
Also, is this a job that's easier with any special tools that the instructions may not mention?
We've found that sometimes instructions will call for tools that are too wimpy, and they don't mention something better that makes the whole job go easier. But we don't find that out till after we have struggled through with the inadequate tools, and we learn the hard way! If there's anything you know of that would help us to not learn the hard way, please share!
Old 08-29-2008, 09:40 PM   #5
concretemasonry's Avatar
Before you jump take a close look at the existing opening/frame and trim - its soundness, level, plumbness, consistancy of dimensions and squareness. - If it looks questionable , it is nt a DIY job.
concretemasonry is offline   Reply With Quote
Old 08-30-2008, 01:04 AM   #6
Thanks...will definitely check into those things before we get too far into this! I sure hope it's all sound & straight.
Old 08-30-2008, 07:38 AM   #7
747
registered
747's Avatar
Mine are high end larsons. Actually the most expensive lowes had. I like them. They have the full paine glass which is etched. I can remove in summer and install full screen. CAn you install yourself. Will you get in way over your head Did i install mine I'm not that stupid The guys who do it make it look easy. Its not. Here is exactly what my two storm doors look like for the front entry door and the side entry door of my house. http://www.larsondoors.com/script/attrvalue.asp (model no.349-14)
747 is offline   Reply With Quote
Old 08-30-2008, 02:53 PM   #8
The high-end Larson doors look very nice!
The Pella brochure at Lowes describes an Express Install feature for "quicker, easier installation" in "as little as 60 minutes." Preassembled parts. No Cutting. Door and frame factory-assembled. Holes predrilled.
Has anybody worked with one of these?
Are Andersons a lot better?
Can't wait to get this worked out and have the doors actually on the house!
Old 08-30-2008, 11:52 PM   #9
BUILDER / REMODELING CONT
buletbob's Avatar
I'm not fermilular with pella, ANDERSON is a very good door, AND the high end LARSON , BOB
Old 08-31-2008, 03:26 AM   #10
Good luck.
I think there is nothing difficult to do anything in this world if we can follow simple instructions and manuals. So be brave and go for installation.
Last edited by AtlanticWBConst.; 09-02-2008 at 08:08 AM. Reason: Site Rules Violation: Advertising Link Removed from Signature
wilsonmian is offline   Reply With Quote
Old 09-02-2008, 07:55 AM   #11
gravity always wins
I've installed Andersens and Larsens. They were almost identical. I wouldn't be surprised if they weren't made in the same place. They can be a real challenge if the old jamb is out of square or plumb. The OP didn't say how much they planned to spend. Plan on plenty if you want a high end door. There are prehung storm doors that will go up much quicker although they are a lower quality door. You get what you pay for.
Old 09-02-2008, 09:55 AM   #12
Andersen storm doors are actually Emco doors, they bought the company. Pella doors are the old Cole Sewell door company, which they purchased. Cole Sewell had major problems with their wood(flakeboard) core doors. Water would get into the flakeboard and release chemicals that would eat away the aluminum. I had one customer who replaced 4 doors in 6 years under warranty.
Larson and Andersen are separate companies.
Ron
Old 09-02-2008, 11:26 AM   #13
I just installed 2 doors last week on my own home. I've done a few over the years. The front is a Larson and the back is a Pella. Different style doors and neither company offered both.
Both doors have good instructions. Read from start to finish before you begin. Typical homeowner tools. The Pella supplied the 7/8 spade bit with the door for drilling for the handle. Both were left or right hand optional installation, you choose so that's why they were not drilled for the handle and lock. Save some time here if you go with pre-drilled.
I went with the higher end because of insulation and glass options. Front full glass (removable) and back with a pull down hidden screen 1/2 glass and paneled bottom. Both have a decent lock included.
They say they can install in 60 min. Probably if you do it often. Took me 3 hrs for the first door.
Again, read the instructions all the way through before you begin. Identify the parts and understand what they are telling you to do. Cutting is easy with a good metal blade in your hack-saw. Only cuts were the bottom of the hinge It really isn't hard if you take your time. The second one will go much faster. I've included an image of one page of the instructions. Go to the Mfg site and they all have instructions on-line.
That's my ol' 2¢
Shamus
Shamus is offline   Reply With Quote
Old 09-02-2008, 04:50 PM   #14
That's my ol' 2¢
If you've done a few over the years, then you qualify as experienced! Thanks for sharing insight. I will pre-study it all as much as possible, especially online, and get together the tools to put in my husband's hands on Saturday!
Question about the 2 brands you chose: Was the Pella easier to install than the Larson?
He shopped the Labor Day sale at Lowe's yesterday. Now we have a Pella Select Series storm door for the front that says it's "Express Install", and a screen-away Larson Tradewinds Fullview for the kitchen. The Larson screen-away door for the kitchen seemed sturdier than the Pella screen-away they had on display.
Old 09-02-2008, 04:55 PM   #15
It seems straight & square, and mostly sound. There was a little crack on the outside trimwork from where they replaced that exterior door last year, and put the old trim back in place. I spackled it and painted over it, but I know it's still there. Not sure if that crack will matter?
Should I replace that trim before working on the storm door there?
Do you have any specific advice for checking the door opening other than looking at it and measuring for consistency?
how to install sliding glass doors but baseboard heat reg. is in the way chas2jones HVAC 1 08-11-2008 06:31 PM
Storm doors sk8z Remodeling 1 04-01-2008 10:28 PM
want to install blinds on sliding doors joy0912 Interior Decorating 2 09-26-2007 07:18 PM
When to Install Pre-Hung Interior Doors For New Construction Hages Carpentry 5 03-01-2007 10:34 PM
Install floating floor or my doors first? jtr Flooring 3 11-16-2006 10:21 PM
