Install A Security Camera Outisde? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-26-2013, 06:50 AM   #1
Eclipsepower's Avatar
Install a security camera outisde?
Hey guys I plan on installing a security camera outside my front porch that uses. The camera uses an AC plug fitting and have consider two option and wanted to know if it is possible.
A: Splice the AC plug and connect the wire to the front porch house main wires.
B: Connect an AC outlet to the front porch house main wires.
The wires that I have are 7 in total. They are all connected to a light sensor which been working great for years.
Black/White/Red to the sensor and Black/White to both of the light.
What is my best option and how can I do this? Thank you
The AC power plug info:
1 AC input voltage ……100-240VAC (Global)
2 Input frequency ………47-63Hz
3 AC inrush current(max.) …….20A/230V
5 4Line regulation (full load).......±0.5%
6 Peak- to -peak ripple …….<100MV
7 Working temperature………….0-35℃-100% ,50℃-70% load
8 Setup rise hold up time………100ms,50ms,20ms-240VAC input
9 Strong made totally compatible part
10 Over voltage protection………115%-135% rated output voltage
11 Withstand voltage………I/P-O/P 3Kvac,1 minute
12 Over load protection ………115%-135%fold back current limiting, Auto-recovery
Eclipsepower is offline   Reply With Quote
Old 09-26-2013, 09:44 AM   #2
Rewards Points: 760
the ac adapter must be inside the house, does the camera have some 2-3 foot wiring to go inside the house like this
http://www.doityourself.com/forum/at...831_075142.jpg
carmusic is offline   Reply With Quote
Old 09-26-2013, 09:46 AM   #3
joed's Avatar
Rewards Points: 12,854
The light might be switched only. You don't want your camera on switched power. You can not connect direct to the house supply. You need to install a receptacle.
Old 09-26-2013, 03:58 PM   #4
Hey carmusic, I do use a wifi ip camera. However, I want to get the wire connected from the outside, not inside the house.
Hey joed, the light sensor works all the time, there is no switch to turn it on or off. It just goes by the sensor.
Old 09-26-2013, 06:59 PM   #5
Well I went ahead and fixed it myself. I pulled the 7 wires reveling the 3 wires I needed to add the receptacle. I took the easier option.
Thank you , this thread can be closed.
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
drilling into steel door all the way thru for inside security bar install docjlb Building & Construction 4 12-18-2010 04:48 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
