Install Manholes (access) Hole In Concrete Septic Tank Cover - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 04:26 PM   #1
Rewards Points: 83
Install manholes (access) hole in concrete septic tank cover
The septic tank at my house built in the mid 1970s has a three piece concrete lid (3 rectangular sections ) . When I have had it pumped , they usually dig enough soil to remove one section of the cover . They have "offered" to installed a manhole or something for $200 . I would like to install something like two 12"-24" manholes (risers and access covers ) so that I can maintain a filter on the outlet tee , monitor the inlet tee and make pumping less destructive to the landscaping . My questions is mainly how do I cut the holes in the concrete cover sections without damaging them (don't have to perfectly round or smooth ). - Thanks
example of septic tank risers - http://www.zoeller.com/zcopump/Produ...ite/risers.htm
example - of septic tank outlet tee filter - http://www.thenaturalhome.com/septicfilter.htm
rkpatt is offline   Reply With Quote
Old 02-12-2009, 05:15 PM   #2
Contractor
cobracdn's Avatar
Can you post a picture please? Cheers
cobracdn is offline   Reply With Quote
Old 02-23-2009, 06:37 PM   #3
Drywall contractor
Rewards Points: 1,070
You will need to contact a company that specializes in concrete cutting and "coring" (drilling holes). You don't have the tools to cut through a 6" concrete slab, I'm guessing. Wouldn't be worth buying unless you plan on going into the business.........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
How to drill 6-8" hole in reinforced concrete? Jemo Remodeling 2 02-26-2007 01:36 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
