Inside Water Consumption - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-06-2007, 07:30 PM   #1
Exclamation
HELP...Water in den coming up from underneath the floor
I'm a new member here and since we've just purchased a home a month and a half ago, I will most likely be here quite a bit. Anyway, our immediate problem is we've had a lot of rain here in South Texas recently, and we've noticed a water spot in front of the patio doors that lead into the backyard. We're not sure where this is coming from, our only guess is that rain water is seeping under the house somehow and coming up through the carpet, but it's just in the one area right in front of the patio doors. Any help would be greatly appreciated!
David-N-Karee is offline   Reply With Quote
Old 07-06-2007, 09:43 PM   #2
weekend warrior
Rewards Points: 150
Check the flashing/channeling around the slider very carefully, that's probably where it's coming from...
johnny331 is offline   Reply With Quote
Old 07-06-2007, 10:01 PM   #3
At the risk of sounding like an idiot...what exactly is the flashing/channeling? I have regular doors, not sliding glass. I'm not sure if that's what you're referring to or not. Also, I guess I should say, it's not just a spot...but a rather large spot. Thank you !
Old 07-07-2007, 06:58 AM   #4
Is there a gutter above this door?
redline is offline   Reply With Quote
Old 07-07-2007, 09:22 AM   #5
There is no gutters on the house. It's a covered patio, but water does leak down onto the patio. The doors have weather strips and there is a small step up from the patio into the house.
Old 07-07-2007, 01:03 PM   #6
zel
Rewards Points: 150
Send a message via AIM to zel
Is the step up wood or concrete? Water shouldnt be leaking down under the covered patio. The roof above should be water tight to the rest of the house, in my opinion.
zel is offline   Reply With Quote
Old 07-07-2007, 01:56 PM   #7
It's concrete. the patio was an addition and I don't think they did a very good job. Where they have it attached to the house it drip down in a few spots. But nothing to raise the water enough to seep in under the doors. I have a hall bathroom about 5 feet from the big water spot and some water is along that wall leading from the bathroom to the big spot. Do you think it could be a broken pipe under ground?
Old 07-07-2007, 02:09 PM   #8
Is there a basement or crawlspace under the house?
Can you post a photo?
Old 07-07-2007, 02:54 PM   #9
No basement or crawl space. I will take some pictures and post them. Thanks for the help!
Old 07-07-2007, 03:21 PM   #10
This is the stoop from the patio
This is where the patio cover meets the house
And this is the water spot
Old 07-07-2007, 07:20 PM   #11
zel
Rewards Points: 150
Check the toilet wax ring. Is it leaking pretty consistently, or just when it rains? Maybe just when the toilet/sink used alot?
Old 07-07-2007, 07:32 PM   #12
There is absolutely no water in leaking in the bathroom. And the water on the rug seems to be when it rains really hard. We got like 6 inches yesterday alone. It started doing this a few days ago. The patio doesn't flood though, so it's not coming in from there. There is no water on the doors or walls. Could there be so much water on the ground that it's coming up from the foundation?
Old 07-07-2007, 07:38 PM   #13
zel
Rewards Points: 150
Yes, it is not uncommon for completely saturated ground to force water up through the foundation. As for how to fix it, I dont really know. I know there are alot of threads about it though. One thing a guy I know had to do was have a "french drain" installed around his foundation, but I dont know if that helps if the water is coming up through it, or just running in from somewhere.
You might want to pull up the carpet in that area and see if it is coming in from a side wall or up from the floor.
Old 07-07-2007, 07:54 PM   #14
Thank you for all your help! We certainly do appreciate it!
Old 07-07-2007, 09:48 PM   #15
remodeling pro
Judging from the stains on the ledger supporting the metal roof and the green color of the bricks at the lower left of the photo and the condition of the door jambs, I suspect there is a flashing problem at the joint of the patio/house roof and water is getting into the soffitt and running down the inside of the wall. between the bricks and the sheathing. We often find that the flashing on many of these patio roofs is just slipped three or so inches under the first course of shingles.
troubleseeker is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
