Inside Wall Paint Chips - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 06:52 PM   #1
Inside wall paint chips
Hi, I recently purchased a home originally built in 1920. While painting today I noticed an issue with the paint in one of the rooms. My question is twofold:
1. Any ideas why paint would chip off the wall in giant pieces? It seems almost like I could chisel away a lot of the paint, if not all of it!
2. In this same room, there is a steam pipe going up the corner, the inspector made it seem like it was no longer in use, and I would like to remove it, any reasons why it would be there?
The house is in ma, two floors with basement/attic, the room is on 2nd floor. I had read briefly here that if the attic had poor ventilation it could cause trouble, we are getting that rectified in ~2 weeks when the roof is redone. In any event this is my first home, any help would be extremely useful, let me know if you need anymore info.
Thanks,
Dustin
Dsorel is offline   Reply With Quote
Old 07-05-2011, 09:35 PM   #2
Rewards Points: 5,336
Could be paint incompatibility, moisture, no primer or bad prep work.
Older houses were painted with oil paints. If the walls weren't primed prior to transioning to latex, you will have issues. If the paint peels off all the way back to the plaster, could be a lack of primer.
Ron
B. Franklin 1759
Old 07-06-2011, 06:18 AM   #3
Too Short? Cut it Again!
Older houses were painted with oil paints. If the walls weren't primed prior to transitioning to latex, you will have issues. If the paint peels off all the way back to the plaster, could be a lack of primer.
Or all four working against you at once. Quality latex products should have covered oil finishes (will never happen the other way around) but not if the surface was not sanded or otherwise deglossed. I have seen cheap latex where you can almost grab one corner of the room and peel it lose to the other.
Anyhow, whenever transitioning from oil to latex or latex to oil an alkyd primer/underlay is a great equalizer so get in the habit of applying one. Alkyds come suspended in oil based solvents so are confused as oil primers. You work with the same tools like natural bristle brushes and you have to rinse your tools with mineral spirits. As mentioned, if the paint is peeling all the way back to the plaster, you will have to apply a priming sealer and start over.
And buy real paint store primers, underlays and paint. Stay away from the high markup box store crap.
Sounds like at one time you had steam heat in the house? The humidity changes from its use, plus the contraction and expansion of the plaster from heat during seasonal changes can stretch the limits of paint ---especially if placed over in inappropriate primer.
One other note I hope you have considered in your old house and not to make you paranoid. Given its vintage be aware you could have lead in the paint. Protect yourself and abate properly please. Cover central HVAC ducts when sanding and block off rooms you are working on, etc.
As for the pipe you want to get rid of? Without seeing it I do not want to render a firm opinion. If it is part of some legacy steam or hot water heating system that has been permanently disabled you can get rid of it I should think. If there is any chance it is part of a vent system or you are not sure its purpose, I would certainly consult a plumber before tearing it out.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
