Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-29-2011, 03:36 PM   #1
Info on spray in foam insulation
I would like to know where I can purchase spray in foam, and where to lease or trang the sprayer
Alcarte is offline   Reply With Quote
Old 01-29-2011, 03:55 PM   #2
This is the company I bought from: http://www.sprayfoamdirect.com/ . It's called Foam It Green.
Everything you need comes with it, but you'll want to buy an extra package of tips.
I looked at HD, Lowe's, Menards and some local hardwares and nobody sells it around here.
One small hardware had a spray gun for dispensing Great Stuff foam in the big cans, which would be a great deal if you're not planning on spraying large areas.
gma2rjc is offline   Reply With Quote
Old 01-29-2011, 04:00 PM   #3
Thanks a bunch
Old 01-30-2011, 09:03 AM   #4
Here is another company to look at.
http://www.tigerfoam.com/
MBatson is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Is spray foam insulation that much better than fiberglass? HautingLu General Discussion 18 09-21-2010 07:36 PM
conflicting spray foam insulation warnings yogi Building & Construction 8 10-01-2009 11:24 PM
Pipe Insulation: Foam or Rubber? EE playing with HVAC HVAC 2 11-01-2008 02:35 AM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 11:14 AM
