Indirect Hot Water Tank - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 07:42 PM   #1
indirect hot water tank
Hi any one there can give me info on how to install indirect hot water tank to in floor heating systam, i all ready have a boiler 300.000 btu boiler so it can handl extra loop. there are so many ways of doing this more you look in to it more confused i get. i have installed my in floor heating systam my self and it works great.
kvdiesel is offline   Reply With Quote
Old 10-01-2009, 06:40 AM   #2
Remodeling Contractor
you will need to ask a more specific questions. do you want separate controls? are you planning to use outside air to help anticipate radiant heat needs? Will you go with the shared or isolated water supply? How many zones?
Old 10-06-2009, 12:11 AM   #3
hot water tank
Hi Bob i have 7 zone's, going to use shared water and seperate control. I have a in floor heating systam.
thanks
Old 10-06-2009, 10:32 AM   #4
So what are you questions? Which part of this system are you not sure of?
Old 10-08-2009, 08:28 AM   #5
Rewards Points: 5,336
Many manufacturers warn you not to use a tankless unit in this way.
Ron
Old 10-08-2009, 11:54 AM   #6
Ron
Yeah I wouldn't think those tankless units are designed to be run for continuous usage.
Viper16 is offline   Reply With Quote
Old 10-08-2009, 09:15 PM   #7
I like to conbine my indirect hot water tank to mr boiler, i like to know do i need 2ct circulator pump?
Old 10-09-2009, 07:52 AM   #8
From your posts, it seems you need professional help. I suggest you get it.
Ron
Need help with smelly and black well water!! HABSFAN2006 Plumbing 20 04-27-2009 11:54 PM
Indirect vs. Stand Alone Water Heater Clutchcargo Plumbing 0 11-24-2008 10:03 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 11:53 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
