Incandescent Lightbulbs - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 03:05 PM   #1
incandescent lightbulbs
So the good old fashioned tried and true lightbulb is to be banned as Jan.1 2014.
Ok I thought.. I will try to be eco friendly and save hydro. But when changing a bulb out in my sons room today a fresh one broke. The following is the recommended clean up process.
1 remove all living creatures from the area
2..open a window??? Its freaking minus 19 c ..OPEN A WINDOW ??? How on earth is that energy efficient??
3) wear facemasks...gloves...and change your clothes..deposit them in an airtight bag
So the light bulb is banned and they give us poison instead..is this a joke??
I'm heading to the store to stock up on incandescent..to heck with saving a few pennies and quite frankly I don't find that they last ANY longer.
Ok Rant over.
.http://www2.epa.gov/cfl/cleaning-broken-cfl-0
EPA
Cleaning Up a Broken CFL
Steps to Take When a CFL Breaks
Download and print instructions
Recommended steps:
Before Cleanup
  1. Have people and pets leave the room, and avoid the breakage area on the way out.
  2. Open a window or door to the outdoors and leave the room for 5-10 minutes.
  3. Shut off the central forced-air heating/air conditioning (H&AC) system, if you have one.
  4. Collect materials you will need to clean up the broken bulb:
    • Stiff paper or cardboard
    • Sticky tape (e.g., duct tape)
    • Damp paper towels or disposable wet wipes (for hard surfaces)
    • Glass jar with a metal lid (such as a canning jar) or a sealable plastic bag(s)
Top of page
Cleanup Steps for Hard Surfaces
  1. Carefully scoop up glass fragments and powder using stiff paper or cardboard and place debris and paper/cardboard in a glass jar with a metal lid. If a glass jar is not available, use a sealable plastic bag. (NOTE: Since a plastic bag will not prevent the mercury vapor from escaping, remove the plastic bag(s) from the home after cleanup.)
  2. Use sticky tape, such as duct tape, to pick up any remaining small glass fragments and powder. Place the used tape in the glass jar or plastic bag.
  3. Wipe the area clean with damp paper towels or disposable wet wipes. Place the towels in the glass jar or plastic bag.
  4. Vacuuming of hard surfaces during cleanup is not recommended unless broken glass remains after all other cleanup steps have been taken. [NOTE: It is possible that vacuuming could spread mercury-containing powder or mercury vapor, although available information on this problem is limited.] If vacuuming is needed to ensure removal of all broken glass, keep the following tips in mind:
    • Keep a window or door to the outdoors open;
    • Vacuum the area where the bulb was broken using the vacuum hose, if available; and
    • Remove the vacuum bag (or empty and wipe the canister) and seal the bag/vacuum debris, and any materials used to clean the vacuum, in a plastic bag.
  5. Promptly place all bulb debris and cleanup materials, including vacuum cleaner bags, outdoors in a trash container or protected area until materials can be disposed of. Avoid leaving any bulb fragments or cleanup materials indoors.
  6. Next, check with your local government about disposal requirements in your area, because some localities require fluorescent bulbs (broken or unbroken) be taken to a local recycling center. If there is no such requirement in your area, you can dispose of the materials with your household trash.
  7. Wash your hands with soap and water after disposing of the jars or plastic bags containing bulb debris and cleanup materials.
  8. Continue to air out the room where the bulb was broken and leave the H&AC system shut off, as practical, for several hours.
If you have further questions, please call your local poison control center at 1-800-222-1222.
Top of page
Cleanup Steps for Carpeting or Rugs
  3. Vacuuming of carpeting or rugs during cleanup is not recommended unless broken glass remains after all other cleanup steps have been taken. [NOTE: It is possible that vacuuming could spread mercury-containing powder or mercury vapor, although available information on this problem is limited.] If vacuuming is needed to ensure removal of all broken glass, keep the following tips in mind:
    • Vacuum the area where the bulb was broken using the vacuum hose, if available, and
  4. Promptly place all bulb debris and cleanup materials, including vacuum cleaner bags, outdoors in a trash container or protected area until materials can be disposed of. Avoid leaving any bulb fragments or cleanup materials indoors.
  5. Next, check with your local government about disposal requirements in your area, because some localities require fluorescent bulbs (broken or unbroken) be taken to a local recycling center. If there is no such requirement in your area, you can dispose of the materials with your household trash.
  6. Wash your hands with soap and water after disposing of the jars or plastic bags containing bulb debris and cleanup materials.
  7. Continue to air out the room where the bulb was broken and leave the H&AC system shut off, as practical, for several hours.
Top of page
Future Cleaning of Carpeting or Rugs: Air Out the Room During and After Vacuuming
  1. The next several times you vacuum the rug or carpet, shut off the H&AC system if you have one, close the doors to other rooms, and open a window or door to the outside before vacuuming. Change the vacuum bag after each use in this area.
  2. After vacuuming is completed, keep the H&AC system shut off and the window or door to the outside open, as practical, for several hours.
creeper is offline   Reply With Quote
Old 12-30-2013, 03:56 PM   #2
Rewards Points: 736
What year is this?
TheBobmanNH is offline   Reply With Quote
The Following User Says Thank You to TheBobmanNH For This Useful Post:
gregzoll (12-31-2013)
Old 12-30-2013, 04:03 PM   #3
Originally Posted by TheBobmanNH View Post
What year is this?
No Kapeesh..
Do you mean (1) what year are we currently in ??
or do you mean(2) what year is this to take place??
1) 2013
2) 2014..as in tomorrow night
Old 12-30-2013, 04:10 PM   #4
Rewards Points: 736
More like I thought we were done with incandescent vs CFL overreaction / hysteria like, 3 years ago.
If you honestly spend more than 8 seconds total in your entire life worrying about light bulbs you should talk to someone.
Old 12-30-2013, 04:11 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,800
apparently in Canada the 75 and 100 watt incandescents are going to be not imported or allowed Jan 1/2014. Jan 1/2015 is the cutoff date for 40 and 60 watt incandescents. Europe has been that way for years and Canada is following and I imagine the US will get there too.
Old 12-30-2013, 04:15 PM   #6
DIY staff
Rewards Points: 7,174
U.S.A.has a ban starting January 1 also----
There is a bit of mercury in those bulbs----We will all become 'The Mad Hatter' soon---
Old 12-30-2013, 04:18 PM   #7
No hysteria here, but I must have missed that particular uproar. Things take a while to reach us up here dontcha know. Just the same thanks for the advice ...I will run it by my shrink
However I do not plan on having any mercury vapour bombs in my home.
Old 12-30-2013, 04:26 PM   #8
Rewards Points: 2,238
Mercury is not good for young children.
(You know - like "creeper" and "--M--"!)
Us old people just figure -
it's going to be this or that - that's going to - "run us to ground"!
We just bought a whole mess of incandescent bulbs!
rossfingal is offline   Reply With Quote
Old 12-30-2013, 04:29 PM   #9
yep creeper and --M--.......spring chickens
Old 12-30-2013, 04:55 PM   #10
Rewards Points: 255
Oh, I dunno... if you have a larger size house or even a small facility for a business there are some non-trivial costs involved, both for electricity cost savings break even time and in some cases, just challenging locations to even change bulbs. And yeah, there's concern about the CFL mercury. (Not to mention lighting design issues for places it matters or people care.)
Thing is, CFLs are bad as it turns out. And quality LEDs are still too expensive and in some cases not ready for prime time. (We've had a couple that seemed reasonably priced from one of the big box stores just crap out immediately. Maybe a problem with the fixture, but still, a disappointing hassle for something that shouldn't have to take 8 seconds to consider.) And some of the new bulbs require upgrades to automated switches to work properly. So it kind of does bear some thought. We're actually making sure we've got a bunch of the plain ole' simple style on hand for the places they make the most sense for us for the medium term future.
Like so many things, it's just become stupidly complicated. Used to be you'd just buy the wattage bulb you needed, maybe with a desired color coating, and that was that. We may consider going back to candles.
Scottg is offline   Reply With Quote
Old 12-30-2013, 05:00 PM   #11
Rewards Points: 626
I love LED lighting they are way better then the floresent bulbs last for ever nothing to burn out, and is almost a very natural light even comes in a soft white light.
Nailbags is offline   Reply With Quote
Old 12-30-2013, 05:13 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Eating tuna can be more of a mercury threat than any cfl
Old 12-30-2013, 05:27 PM   #13
Precisely..thats why I don't have exploding tuna bombs hanging from my son's lighting fixtures
Really..if the gov't is going to ban something that has worked well for decades then they should not limit my choices to mercury anything.
Old 12-30-2013, 05:30 PM   #14
QuickView
Cree9.5-Watt (60W) Warm White LED Light Bulb (1-Pack)
$15.97 $15.97
This price for one bulb is not an option
Old 12-30-2013, 05:33 PM   #15
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Florescent lights hurt my eyes. Guess I will be wearing sunglasses all the time. And the CFLs don't last much longer than incandescents in regular use.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
how to get more reds and yellow out of a incandescent light bulb ahrealy Electrical 6 05-01-2012 05:55 PM
Lightbulbs in Ceiling Fan! kateisstumped Electrical 5 07-20-2011 12:06 PM
incandescent fixtures banned? kainos Electrical 15 06-01-2011 05:12 PM
using 60w incandescent bulbs in fan rated for 15w CFL denemante Electrical 13 03-21-2011 11:33 AM
CFL vs incandescent question adpanko Electrical 13 08-30-2009 10:41 PM
