If Your Running A Generator...? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 06:11 PM   #1
biggles's Avatar
if your running a generator...?
make sure you have extra oil for that gas refill and regapping the plug after a 12 hour run.... i usually do a 6AM to 6PM run on a 4 gallon tank works great
Old 10-29-2012, 02:15 AM   #2
Rewards Points: 12,802
Why in the world would you be regaping a spark plug that often
Total waste of time.
Old 10-29-2012, 07:52 AM   #3
biggles's Avatar
just pull the plug then and clean the carbon off during shut down............gubber
Old 10-29-2012, 10:47 PM   #4
Rewards Points: 262
Does the carbon build up on the plugs that quickly. Just trying to learn about gererators here.
Jim F is offline   Reply With Quote
Old 10-31-2012, 08:36 AM   #5
Rewards Points: 3,130
No, it doesn't. You will see more carbon than you would from the fuel-injected engines of today. Doesn't hurt anything to clean it off every 12 hours, but it is a complete waste of time. I wirebrush the plug on my generator when I change the oil - that's every 100 hours of operation. I've never gapped it.
The Following User Says Thank You to md2lgyk For This Useful Post:
Jim F (11-16-2012)
cost of running cummins generator jimboe General DIY Discussions 7 08-04-2012 07:46 PM
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 11:15 PM
Generator - stand alone feed circuit help? FussyBob Electrical 5 12-13-2010 11:15 PM
REVIEW - Powermeter Pro to Visualize Generator Usage deeze Electrical 13 08-29-2009 10:45 PM
