If You Have A Garage Shop - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 06:24 AM   #1
biggles's Avatar
if you have a garage shop
picked one of these up years ago works great to work on from lawn mowers to cutting wood,drilling,painting stuff just roll in into the corner to store.
Old 08-11-2012, 10:11 AM   #2
bbo
we had a kitchen island in the house when we moved in. Wifey did not like it so I removed it and put some wheels on the bottom.
works great for tabletop tools and projects.
bbo is offline   Reply With Quote
Old 08-11-2012, 06:23 PM   #3
Too Short? Cut it Again!
Sure everybody knows but old doors make great temporary work surfaces and you can use the hole for door knobs for electrical pass through. Two, two drawer file cabinets and a door make a decent desk. Saw horses work for a base too.
When you are done. You can lean the door on edge and out of the way.
Old 08-11-2012, 08:46 PM   #4
firehawkmph's Avatar
Rewards Points: 1,902
Biggie,
I have one of those sitting outside my shop. I usually use it for sanding and spray painting. They do come in handy.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 08-11-2012, 09:07 PM   #5
In a little over my head
Rewards Points: 706
Originally Posted by sdsester View Post
Sure everybody knows but old doors make great temporary work surfaces and you can use the hole for door knobs for electrical pass through....
Solid core's better than hollow core. Raised panel, no so much.
ratherbefishing is offline   Reply With Quote
Old 08-12-2012, 06:59 AM   #6
DIY staff
Rewards Points: 7,174
I save one or two during demolition and use them as throw away work tables.
Old 08-12-2012, 07:49 AM   #7
Rewards Points: 14,026
I have used those type barrels for rain barrels, on job sites to store water to clean paint brushes and drywall tools if the wells not in yet, as drywells for condinsate drains, as a sump pump pit, Cut the cover and lay it on it's side and you have a dog house.
Old 08-12-2012, 08:57 AM   #8
Rewards Points: 1,300
swimming pool winter cover float for me.
danpik is offline   Reply With Quote
Old 08-12-2012, 10:25 AM   #9
biggles's Avatar
i also have one for work with a petcock on the side placed low so it can drain cut top off.ran a plastic flex tube around the top with pin holes,for when i'm recoving freon in a hot mechanical room spray water over the reclaim drum
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 11:02 AM
gfci in detached garage for shop tools n175h Electrical 6 12-28-2011 04:57 PM
