Ideas To Fix Leak From Tub Overflow Faceplate - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-18-2013, 10:52 AM   #1
ideas to fix leak from tub overflow faceplate
Hi,
wanted to get your ideas for a temporary 6mth solution. The picture is from the back of my bathtub, i believe it's the tub overflow faceplate. you can see evidence where the gasket(?) or seal seems to be compromised and as a result water is leaking down the tub, and dropping on my living room ceiling below.
I was thinking that for now (finances are tight and i am not that handy a person) that if i put a bead of silicone caulk from the tubside onto the the circumference of the gasket, that will solve the problem? i don't want to do this if it will cause worse problems down the road.
Any other suggestions to give me a 6 month fix? thanks in advance.
thundercracker is offline   Reply With Quote
Old 12-18-2013, 11:15 AM   #2
K&B Designer
Live_Oak's Avatar
IF that's actually the source of your leak, then simply replace the gasket.
And what are you planning to do 6 months down the road? A gut remodel?
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
thundercracker (12-18-2013)
Old 12-18-2013, 11:17 AM   #3
yes, possible remodel in 6-8 months. how hard to change the gasket, do i have to undo any plumbing, or do i just remove the screws, get the gasket off and put the screws back?
thanks
Old 12-18-2013, 12:10 PM   #4
Rewards Points: 12,794
There's suppose to be a gasket under the cover on the other side inside the tub.
Sure the two screws are not just loose?
Old 12-18-2013, 12:16 PM   #5
i just checked home depot and saw that there is a gasket for the inside of the tub, faceplate. mine doesnt have it. i'll get one and see if that fixes the problem.
thanks
Old 12-18-2013, 12:46 PM   #6
Rewards Points: 166
I had a similar issue, Here is my thread from about a year ago:
Bathtub overflow plate. Is this a problem?
Minus08 is offline   Reply With Quote
The Following User Says Thank You to Minus08 For This Useful Post:
Old 12-18-2013, 01:43 PM   #7
very helpful, thanks very much!
Tags
bathroom tub , leak , overflow faceplate
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 04:34 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 08:46 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
