-   -   ideas to fix leak from tub overflow faceplate (http://www.diychatroom.com/f2/ideas-fix-leak-tub-overflow-faceplate-192273/)
thundercracker 12-18-2013 10:52 AM
1 Attachment(s)
Hi,
wanted to get your ideas for a temporary 6mth solution. The picture is from the back of my bathtub, i believe it's the tub overflow faceplate. you can see evidence where the gasket(?) or seal seems to be compromised and as a result water is leaking down the tub, and dropping on my living room ceiling below.
I was thinking that for now (finances are tight and i am not that handy a person) that if i put a bead of silicone caulk from the tubside onto the the circumference of the gasket, that will solve the problem? i don't want to do this if it will cause worse problems down the road.
Any other suggestions to give me a 6 month fix? thanks in advance.
Live_Oak 12-18-2013 11:15 AM
IF that's actually the source of your leak, then simply replace the gasket.
And what are you planning to do 6 months down the road? A gut remodel?
thundercracker 12-18-2013 11:17 AM
yes, possible remodel in 6-8 months. how hard to change the gasket, do i have to undo any plumbing, or do i just remove the screws, get the gasket off and put the screws back?
thanks
joecaption 12-18-2013 12:10 PM
There's suppose to be a gasket under the cover on the other side inside the tub.
Sure the two screws are not just loose?
thundercracker 12-18-2013 12:16 PM
i just checked home depot and saw that there is a gasket for the inside of the tub, faceplate. mine doesnt have it. i'll get one and see if that fixes the problem.
thanks
Minus08 12-18-2013 12:46 PM
I had a similar issue, Here is my thread from about a year ago:
http://www.diychatroom.com/f7/bathtu...roblem-130513/
thundercracker 12-18-2013 01:43 PM
very helpful, thanks very much!
