Ideas To Enclose/lock Closet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-15-2014, 03:15 PM   #1
Rewards Points: 155
ideas to enclose/lock closet
I have to help build some DIY closet for band uniforms for the high school. We are just going to frame out with 2x6 and use a metal pipe as a closet rod to hang kids uniforms. That part if fairly straight forward- but the instructors want to lock the closet area so people don't touch anything. The framed closet is in a shared area- I'm looking for ideas to hinge or come up with some way to make that area secure- Someone suggested a type of roll up door but I would be that is expensive..... suggestions welcome
Huskyfan68 is offline   Reply With Quote
Old 11-15-2014, 03:21 PM   #2
Rewards Points: 1,710
Barn door hinges, on a 4x8 sheet of plywood, with the cross-buck pattern as a decorative reinforcement. Times two, a left and a right door. with a standard hasp lock assembly.
ED
de-nagorg is online now   Reply With Quote
Old 11-15-2014, 03:38 PM   #3
Rewards Points: 13,468
Why are you using 2 X 6's for framing instead of 2 X 4's?
Why not just use double prehung steel doors? Any box store will have them in stock.
Old 11-16-2014, 07:30 AM   #4
Rewards Points: 654
Do you have little vandals or insecure band leaders? Locking away expensive instruments? Security depends but even a steel lock can be cut, and some of these kids already carry around master keys.
For minimum security, swing out hollow core doors with a hasp, as suggested.
Unless you are set on framing, and finish costs can add up, Ikea bureaus are fairly cheap.
carpdad is offline   Reply With Quote
Old 11-17-2014, 06:38 AM   #5
Maybe this will help...
http://www.diynetwork.com/how-to/how...use/index.html
http://extremehowto.com/build-a-temporary-closet/
http://extremehowto.com/build-a-temp...oset/?page=all
With these two designs it makes the most out of limited space.
The closet can be rolled in and out of the enclosure.
ron45 is offline   Reply With Quote
Should my furnace closet have a huge duct opening into the vented attic? iLikeDirt HVAC 9 04-27-2014 07:13 PM
help: laminate floor leaves a gap around closet alsoufo Flooring 11 11-29-2013 12:06 AM
Additional fan in closet Tankeray General DIY Discussions 11 06-04-2013 05:05 PM
Ideas on small laundry closet?? norm58 Appliances 10 02-01-2013 10:34 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
