Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-09-2012, 01:11 PM   #1
Idea for shelving liner
I have a ton of these in my basement:
http://www.globalindustrial.com/p/fo...FcRa4AodawMA8Q
There great, but since the shelves are wire, small things fall through them.
I'm looking for something to use as a liner that isn't real expensive, looks good and won't mold or stain or scratch. They used to sell this black rubber stuff at home depot in ~3ft wide rolls, not sure if they still do or not. Any other ideas?
tibberous is offline   Reply With Quote
Old 11-09-2012, 01:43 PM   #2
This site on google search has a pretty good selection of non grip and also grip/no slide but it can probably be found locally.
http://www.bedbathandbeyond.com/1/3/shelf-liner
Fairview is offline   Reply With Quote
Old 11-09-2012, 05:17 PM   #3
I found something that is pretty cool, even though there really expensive ($25 for 2 shelves) and take some work.
Basically, lowes sells a 1/4" rubber mat that's 3'x5'. If you cut it down the center with a jigsaw (the hard part), it gives you 2 shelf liners for 18" shelves. There nice because there ridgid and should be near-indestructible, you can't even cut through them with a utility knife.
Shower Pan Liner Jwindsor Plumbing 4 12-01-2011 02:10 AM
chimney liner, excuse for propane furnace upgrade? bubbler HVAC 0 09-16-2011 08:58 AM
Paper or Paint Over Liner Cruss Painting 4 08-15-2011 05:40 AM
Shower Pan- PVC Liner creating bulge in backer board Paul8434 Remodeling 1 06-07-2011 08:48 PM
Sump Pit Liner bta150 Plumbing 3 03-01-2011 10:48 PM
