Ice Dam On New Roof - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 02:45 PM   #1
Ice dam on new roof
I live in northern Indiana
I am having ice build up on a 10' section of my new roof .There is 13" of insulation and good ventilation
It's over the furnance, dryer and hot water heater that is exhausted out of the side of the house at the sill plate level
I believe that's my problem but how do I correct it?
Merlin1
merlin1 is offline   Reply With Quote
Old 02-11-2013, 03:17 PM   #2
Rewards Points: 710
Is there water standing behind the dam as depicted in this link?
http://www.google.com/imgres?imgurl=...9QEwAw&dur=290
Old 02-11-2013, 03:40 PM   #3
Those plug in heating cables never fail.
paintdrying is offline   Reply With Quote
Old 02-11-2013, 04:02 PM   #4
Rewards Points: 13,296
Got a picture?
Old 02-11-2013, 04:17 PM   #5
Rewards Points: 3,418
Merlin1
You've only got an R32 rating and the recommendation for your area is between 49and 60,so you need more as is evident by the ice dam you have now,i'll attach a link for a calculator to see how much more you'll need.
http://www.lowes.com/cd_Blown+In+Ins...ator_748453603_
Canarywood1 is offline   Reply With Quote
Old 02-11-2013, 05:16 PM   #6
http://www.energystar.gov/index.cfm?...sulation_table
Old 02-11-2013, 05:29 PM   #7
Rewards Points: 1,294
Merlin1
I deal with the same issue every winter. My boiler is a sidewall vent also. The heat from it rises up along the outside wall and gets in thru the soffit vents cousing significant ice damming in that area only. Next winter I plan to test a deflector of some sort in that area.
danpik is offline   Reply With Quote
Old 02-11-2013, 06:51 PM   #8
Registered User
Rewards Points: 5,216
Pictures would help...
Gary
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
