Ice Cold Mouldings - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 07:11 PM   #1
Rewards Points: 26
Ice Cold Mouldings
Hello All,
Just started winterizing sealing around the windows, doors and ACs. After I was done I noticed that it was ice cold around where the floor mouldings are in the front and back of the house. The walls and around the windows were the cold mouldings are aren't so cold.
Is this normal? Can I easily fix this?
Thanks,
Andrew
apetrag is offline   Reply With Quote
Old 11-03-2008, 07:47 PM   #2
Rewards Points: 5,336
Fix it, yes. Easily, depends on your definition.
Rim joist insulation might help. There's probably a gap in the insulation at the bottom plate. Hard to fix without removing the baseboard and opening the wall behind it. This way you see exactly what the issue is. A not so "exactly" solution would be to remove the baseboard and drill holes in the sheetrock wall and shoot in some slow expanding foam. I'd try 3-4 holes per bay. If it works, install the baseboard back. If not, see plan ,"A".
Ron
Old 11-04-2008, 06:52 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My first thoughts matched Ron's - Insulate in the rim joist bays (ontop of the foundation frost walls). Try that first, and see what you get....
- Build Well -
Old 11-05-2008, 09:05 PM   #4
Rewards Points: 26
Thanks for the input guys,
Will try this and let you know how it works out.
Andrew
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 10:50 PM
