I Want To Build A "saw Horse" For Firewood - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 02:51 PM   #1
transmitterrecieverpntgun
I want to build a "saw horse" for firewood
I was hopeing someone could help me. I want to build something to put 10 to 15 foot long 6 to 12 inch thick birch tree poles on and cut them at 16 inches with my chain saw. Any one have any motivational thoughts? Pictures? This is still in the thought stages so ANY ideas would be great. I want it to look nice. I will leave it up and functional year round for private cutting on a few acres. Thanks for any help.
utilitylocator is offline   Reply With Quote
Old 02-07-2010, 03:23 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I think the ground, a peavey and a couple already cut chunks of wood works fine.
How do you intend on lifting a 12" diameter 15' long chunk of wood?
Old 02-07-2010, 03:58 PM   #3
In the good old days, they used to use an X frame arrangement to hold logs, while sawing with a 2 man cross cut saw!
Two X's were made from 2X6 material. Then 2-2X6's were run between them in the upper crotch, to form a bed for the log!
It was braced on the legs with two more 2X6's that were run horizontaly. Then two angle brace's were used to stiffen it, to prevent side wobble!
Here's a link to a similar sort of arrangement!
http://www.motherearthnews.com/Moder...d-Storing.aspx
Old 02-07-2010, 04:00 PM   #4
Reading between the lines ... you want to reduce the bending over time on you back... hence get the fire wood in the air?
Speed it way up with 2 strong people working this:
You could build three HD horses... keep shifting one horse back 4' under the logs as you cut... drop the 16" cut wood into a cart or sled attached to your quad runner or small tracktor... to haul for stacking at wood pile near the house or cabin.
Still a lot of effort to get the logs on the horses, but this method could
save some of the constant bending.
lots of variations to this type of approach. All depends on terain and resources.
Big Bob is offline   Reply With Quote
Old 02-07-2010, 04:05 PM   #5
Registered User
Rewards Points: 5,514
http://books.google.com/books?id=vPx...age&q=&f=false
http://books.google.com/books?id=6uE...age&q=&f=false
http://books.google.com/books?id=BMo...age&q=&f=false
Be safe, Gary
Old 02-07-2010, 04:55 PM   #6
nap
You talking to me?
nap's Avatar
How about you giving some ideas as to what you are looking for and what you have to help you use this appliance.
how high off the ground
what machinery, if any, do have the use of to lift the logs
do you have a source of metal and the means to fabricate and weld
I could give a lot if different ideas but if you cannot avail yourself of them for whatever reason, it would be a waste.
Old 02-07-2010, 06:42 PM   #7
Household Handyman
Rewards Points: 1,408
Years ago my wife's Grand Dad showed me how to build "saw bucks" just for that purpose. BUT--not for those sized logs! Getting them onto the saw bucks would be the trick. Re: Your location--my daughter/boyfriend live in Fairbanks. Darrell has a "Tree Trimming /Arborist Service", and he is a high-voltage lineman with a private utility contractor. Darrell shares some stories about running power lines at this time of year. Darrell Laird/Fairbanks. David
Old 02-07-2010, 09:49 PM   #8
Old School
Willie T's Avatar
Nap, you must have tried to lift the same 12" logs I've struggled with... and mine were only 4 or 5 feet long. If this stud is going to lift 15' 12" logs up onto a sawhorse, I sure hope I never meet him in a dark alley.
Willie T
Would like to build kitchen cabinets handyhall Carpentry 8 06-28-2009 11:15 AM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 07:13 PM
Arcade Cabinet build from scratch in MDF and Plexi lokesen Project Showcase 20 10-05-2008 08:50 AM
Sister floor joists or build support wall? Bcoleman6 Building & Construction 3 02-21-2008 01:06 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
