I Removed Shower Caulk And See Lots Of Brown Particles. Is This Water Damage?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-05-2015, 01:52 PM   #1
Rewards Points: 40
I removed shower caulk and see lots of brown particles. Is this water damage??
I own a condo that was built in the 1940s. The tub is the original. I removed some caulk in my tub in order to re-caulk it. There is a small layer of brown dirt-sized particles behind the caulk in the seam. It is easy to vaccum up.
Is that a sign of water damage done to the walls behind the shower?
Should I just re-caulk it and forget it? Or is it a sign of mold?
99blue is offline   Reply With Quote
Old 03-05-2015, 03:03 PM   #2
Rewards Points: 144
Hard to tell without pictures.If water has gotten into the wall behind you re just going to seal it in with caulk and it will do further damage.You need to start by fixing the source of the problem.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
99blue (03-05-2015)
Old 03-05-2015, 04:03 PM   #3
Rewards Points: 40
The caulk I removed was cracking in the seam. I removed the caulk in order to let it dry for a few days. However, the brown dirt-particles that came out were already completely dry.
Old 03-05-2015, 06:41 PM   #4
kwikfishron's Avatar
Rewards Points: 194
I'd rather see dry dirt/dust coming out of the joint than anything wet. Unless you see any potential issues on the other side of the wall or below it then just clean it up and caulk away.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
99blue (03-05-2015), Windows on Wash (03-05-2015)
