I Need Short Logs Milled In Long Island = Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-03-2012, 09:15 AM   #1
I need short logs milled in Long Island = Help
Need some advice as I'm really not willing to let these prime pieces of black cherry logs go.
I had a large black cherry tree fall in the hurricane. As I was surfing the web as to how to replace this tree (it was one of my favorites), I learned (too late) the value of the wood. I had already had the tree cut up into pieces less than 4 feet and some only 1.5 ft.
I live in long Island and am thinking of going with a horizontal band saw or an Alaskan Chainsaw Mill. I was thinking of lining up all the same diameter pieces in a row against the foundation of my home, set back with a couple of cinderblocks to give clearance when I get to the end of the horizontal pieces near my foundation.
Having trouble finding a shop with a horizontal bandsaw service where I live or any other shop that can mill my wood.
Anybody else have any ideas?
pamefs is offline   Reply With Quote
Old 12-03-2012, 09:25 AM   #2
Rewards Points: 13,228
Might want to go back and add your location in your profile in case someone here is near you.
I'm thinking that's not a great choise of wood for direct ground contact.
I'd be looking for a real saw mill.
pamefs (12-03-2012)
Old 12-03-2012, 10:39 PM   #3
Need short logs milled
Thanks Joe. I'll add my location and I agree with you that this should be done on some sort of platform or sawhorses, still trying to figure out the setup.
Old 12-03-2012, 10:45 PM   #4
No I mean take it to a real place that cuts up logs, a saw mill.
It would only take them a few min. to cut them up.
Old 12-03-2012, 10:50 PM   #5
bbo
saw a guy in remote Alaska using a chain saw mill. ( one of the DIY shows) looks like someonw with a good amount of experience with a chainsaw could do this.
lots of google info on this
bbo is offline   Reply With Quote
Old 12-04-2012, 12:31 AM   #6
DIY staff
Rewards Points: 7,174
Go to Woodworking Talk---the link is at the bottom of the page----then got to forestry and logging---
Darren has a list of mills---I believe there is one on long island---also--- Woodmizer keeps a list of bandsaw mill owners--so check out their site----
Old 12-05-2012, 11:48 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... You now have cherry Firewood,...
If you bought a chainsaw, 'n Alaskan chainsaw millin' attachment, you need to do each piece, Individually, not strung together against a chunk of concrete..
In that case you'll have over a Grand into some tiny pieces of rough cut very short lumber,...
aka; Kindlin' wood...
'n as far as Havin' it sawn for ya,...
That ain't gonna happen, for several reasons,......
The 1st is, a saw mill will Not saw residential trees,...
To much metal in 'em...
A Sawyer values his saw blades, Way above yer logs/ lumber..
The 2nd reason is, yer so called "Logs" are to short to mount in a saw carriage...
8' is 'bout minimum length,...
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
