Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-10-2013, 08:39 PM   #1
I dont know how to open drain on water herater w/ pic
Well I was all set to drain my water heater... Except Im not sure how to ope the valve to let out the. The owners manual shows a valve just like a hose. I already attached the hose in the pic. I can turn the entire white thin behind the hose, but the whole assembly seems to move and I got nervous.
Anyway, please see the pic and let me know how to open this thing.
Total Tool is offline   Reply With Quote
Old 02-10-2013, 08:45 PM   #2
That's the way it's suppost to work.
Total Tool (02-10-2013)
Old 02-10-2013, 08:48 PM   #3
so just turn the big nut, which also turns the male end and hose?
Thanks, I got nervous when it all spun. You know, 50 gallons of hot water.
Old 02-10-2013, 08:49 PM   #4
MarginallyQualified
Just like any garden hose spigot. Tighty righty and lefty loosey
Look close and you'll see an arrow in the white plastic molding.
Of Note: turn the heat down and the inlet water off before you start.
Also... plan to REMOVE that utter garbage factory valve and replace it with
a "full port" ball valve so the crud can pass more easily. A few other fittings (nipples, GH adaptor, etc) will come in handy when you do that job.
TarheelTerp is online now   Reply With Quote
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 02-10-2013, 08:54 PM   #5
That would be garden hose adapter.
Old 02-10-2013, 09:04 PM   #6
Yeah, I got it now. I would have just gone for it if it wasnt disfiguringly hot
Wouldnt a ball valve be a bad idea with kids?
Old 02-10-2013, 09:12 PM   #7
MarginallyQualified
Y
Tie wire it if they're the nosy pokey sort.
Or remove the handle.
Keep it nearby (but you only need it for 30 minutes once a year or so).
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Main drain water back ups destroyer427 Plumbing 7 04-07-2009 01:58 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Water softener & Iron filter drain DSKUP Plumbing 3 02-17-2009 11:14 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
