I Could Use Some Guidance On New Roofing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 03:16 PM   #1
I could use some guidance on new roofing
Greetings all. We just purchased a house in December, new construction. Every time we have winds over 20 mph we are having shingles tear away and scatter through the yard. This has happened 5 times in the last 2 months. My question is, to whom do I turn to fix this? Is it the builder? The shingle manufacturer? The roofing sub? My insurance?
At the rate it's going, I'll have to build temporary housing for the roofers I have to keep calling.
Any help or suggestions would be appreciated!
DonB
DonB is offline   Reply With Quote
Old 02-26-2008, 04:20 PM   #2
Rewards Points: 12
I would start with the builder, he hired the roofing subs right? Sounds like the shingles were not installed correctly and you probably need a whole new roof.
ponch37300 is offline   Reply With Quote
Old 02-29-2008, 08:39 PM   #3
In winter shingles will not properly seal, you need heat. Temps should be above 45 degrees at least to get the tar strips to seal. All the roofers I use put tar (Black Jack or similar) down on each shingle when they install it in the winter this creates instant adhesion (Course they charge more but the job gets done). It sounds like your roofer did not do this. I'd go after the GC. It is a install error.
jiggyjack is offline   Reply With Quote
Old 02-29-2008, 11:45 PM   #4
Rewards Points: 5,336
The guy moved into the house in December. The roof was put on months ago. Long enough for the shingles to have sealed down.
Can you post a picture or two?
The house should be covered by the builder. I would get him after I had some roofers look at it and get their opinion. This way you can speak to the builder knowing what's wrong. It's up to him to make it right.
Ron
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
Metal roof??? Tdoggy187 Roofing/Siding 51 03-04-2008 04:35 PM
Roofing felt mattflytx Roofing/Siding 2 09-10-2007 12:01 AM
