-   -   Husky Cement Mixer (http://www.diychatroom.com/f2/husky-cement-mixer-126067/)
jm0027 12-09-2011 04:43 AM
Husky Cement Mixer
How do you remove the drum on a husky cement mixer? Does the pin in the shaft need to come out and how?
oh'mike 12-09-2011 05:16 AM
Post the model ---there might be a manual on line--
Or a picture of the shaft---
jm0027 12-09-2011 05:38 AM
1/2 HP Portable Cement Mixer
Model # 105890DPT It came from Home Depot. There is a threaded rod inside the drum that I was able to remove but the pin in the shaft behind the drum won't budge...
oh'mike 12-09-2011 05:51 AM
I googled Husky cement mixer repair manual 105890dpt----and your post was #1 on the search:laughing:
No luck on the manual---Just a thought if someone here can't help--
Depot rental centers have a tool maintenance guy--they tend to be pretty good sources of information--as they fix so many different tools---ask them if they could look at the machine and tell you how to pop off the barrel---Mike---
pawonfire 12-16-2011 03:08 PM
I have a husky cement mixer, not sure which model number. To take mine apart:
Remove the T-handle bolt inside the barrel. I had to use a large hammer, since there was a bit of dried cement around the bolt. Since I already had the hammer out, I spent some time beating the rest of the dried cement out of the barrel. Figured it would be lighter when I took it off.
Next, grab ahold of the barrel and pull. You may have to rock it to unstick the barrel from the shaft.
The frame disassembled by removing various cotter pins.
