Hunter Model 44860 Programmable Thermostat - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-04-2010, 07:48 PM   #1
Question
Now that it has gotten warmer, I just tried to turn on the COOL function of my thermostat. The outside unit kicks on and starts running, but the fan is not blowing anything. This happened last year and my HVAC guy done something to the thermostat and it started working. I really hate to pay him another $100.
Any ideas why this is happening?
Mark Rhea
Blountville, TN.
markrhea@gmail.com
MarkRhea is offline   Reply With Quote
Old 04-04-2010, 08:22 PM   #2
biggles's Avatar
Hunter tech support 7AM to 7PM CST m-f 1-888-830-1325...here is the manual if you don't have it might be stat isn't set for cooling system just furnace http://www.hunterair.com/ssi/pdf/hun...ers-Manual.pdf
Old 04-05-2010, 10:00 AM   #3
If there is a Fan setting on the thermostat make sure it is set to auto or try putting it to On and see if its workin then. Auto should allow the fan to turn on only when the outside unit is on as well. If all the Hvac guy did was last was mess with the thermostat and no one since has tampered with the wiring then it just sounds like the fan setting is turned off. The manual should help then.
I would also check to make sure your blower unit isn't turned off for some reason as well. There may be a switch located on the unit or the breaker could be tripped.
Best of luck, post back if you have more questions
Cmudr1 is offline   Reply With Quote
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 01:52 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
Hunter 44668 Thermostat - Heat won't turn off ToneyRes HVAC 9 10-18-2009 08:50 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 09:58 PM
