Humidity Meters - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 09:38 AM   #1
Rewards Points: 236
humidity meters
i am looking for one that is at least mostly accurate. and hopefully not expensive. walmart has some, but looking at all of them, some had different readings. so i thought i would ask before buying.
Fix'n it is offline   Reply With Quote
Old 10-28-2012, 09:46 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
Are you wanting to test humidity in a room or moisture in a floor? 2 entirely different things.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-28-2012, 10:06 AM   #3
Rewards Points: 236
i want to place it in a room.
Old 10-28-2012, 03:09 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
I have Springfield gauges in my office ..... if you can't find one you like why not make your own? http://www.ehow.com/how_4443876_make...ity-meter.html
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-28-2012, 03:20 PM   #5
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
Get or make a sling psychrometer, and then use a psychrometric chart. That is how the meteorologists do it.
A psychrometer has two thermometers on it. One is a plain old thermometer, the other is a plain old thermometer with a bit of cotton wick slipped over the end.
When you wet the wick and blow air over it, it cools off (like a sweaty t-shirt). Like a sweaty t-shirt, the moisture cools you off if the air is dry and the moisture can evaporate. If it is really humid you don't get much evaporation and therefore don't get a lot of cooling. So having both a wet bulb temperature and a dry bulb temperature tells you something about the humidity in the air.
With those two measurements you go to a psychrometric chart, where the two temperatures intersect tells you your humidity (and a lot of other things).
http://en.wikipedia.org/wiki/Psychrometrics
Thunder Chicken is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
sweating double pane windows etch Windows and Doors 6 10-31-2011 09:30 PM
Condensation amyevans Windows and Doors 6 10-21-2011 10:11 PM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
