-   -   humidity meters (http://www.diychatroom.com/f2/humidity-meters-161392/)
Fix'n it 10-28-2012 09:38 AM
humidity meters
i am looking for one that is at least mostly accurate. and hopefully not expensive. walmart has some, but looking at all of them, some had different readings. so i thought i would ask before buying.
rusty baker 10-28-2012 09:46 AM
Are you wanting to test humidity in a room or moisture in a floor? 2 entirely different things.
Fix'n it 10-28-2012 10:06 AM
i want to place it in a room.
GBrackins 10-28-2012 03:09 PM
I have Springfield gauges in my office ..... if you can't find one you like why not make your own? http://www.ehow.com/how_4443876_make...ity-meter.html
Thunder Chicken 10-28-2012 03:20 PM
Get or make a sling psychrometer, and then use a psychrometric chart. That is how the meteorologists do it.
A psychrometer has two thermometers on it. One is a plain old thermometer, the other is a plain old thermometer with a bit of cotton wick slipped over the end.
When you wet the wick and blow air over it, it cools off (like a sweaty t-shirt). Like a sweaty t-shirt, the moisture cools you off if the air is dry and the moisture can evaporate. If it is really humid you don't get much evaporation and therefore don't get a lot of cooling. So having both a wet bulb temperature and a dry bulb temperature tells you something about the humidity in the air.
With those two measurements you go to a psychrometric chart, where the two temperatures intersect tells you your humidity (and a lot of other things).
http://en.wikipedia.org/wiki/Psychrometrics
