Huge Bubble In Bathroom Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 07:41 PM   #1
Huge Bubble in bathroom drywall
Can you guys tell me what this bubble is?
This picture is of the place above my shower head in my bathroom.
Should I get this all fixed right away?
adamstan is offline   Reply With Quote
Old 01-19-2011, 08:04 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Water.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-19-2011, 08:15 PM   #3
Originally Posted by rusty baker View Post
Water.
Should I pop it?
Old 01-19-2011, 08:18 PM   #4
Rewards Points: 182
Why not?
Old 01-19-2011, 08:31 PM   #5
Whatever comes out is going to drain onto my faucet, and I think it's going to be gross asbestos liquid stuff, so I'd rather let it dry up there if that's an option.
Old 01-19-2011, 08:49 PM   #6
I'm pretty sure that's water. Your best bet would be take the drywall out, and see were the leak is coming from. You really don't want to leave that alone -- get on it immediately.
suprvee is offline   Reply With Quote
Old 01-19-2011, 10:09 PM   #7
Faron79's Avatar
Rewards Points: 260
Yes...
Get that water bubble drained NOW.
Remove ALL that sheetrock, ceiling and wall, or you'll have mold there soon.
If you don't already....
Call a knowledgeable plumber.
Somethings leaking bigtime!!!
Faron
Faron79 is offline   Reply With Quote
Old 01-20-2011, 04:09 AM   #8
Originally Posted by adamstan View Post
Should I pop it?
Pop it now and take care of the problem. If you don't it will get worse and ruin the entire ceiling/wall. Gets more expensive the longer you wait. You really shouldn't have let it get that bad. First sign of a bubble means a water leak.
NewEnglandYank is offline   Reply With Quote
Old 01-20-2011, 07:41 AM   #9
Rewards Points: 516
Also, provide detail if you live in a single home or apartment complex. If there is another bathroom above this one? Is it a top floor with a lot of snow on roof? Recent heavy rain?
If it's from your shower, don't use it until repair is made. OK to pop bubble.
diyorpay is offline   Reply With Quote
Old 01-20-2011, 08:54 AM   #10
Rewards Points: 5,336
You have a water leak above that room you need to have repaired.
Ron
Old 01-20-2011, 02:52 PM   #11
I live in an apartment building. So you guys think it's because of the guy above me? I will have to get my landlord in here to get this all ripped out.
Old 01-20-2011, 03:05 PM   #12
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I had a similar situation when my wife and I were in our first apartment. The people above us had a leak from their shower drain, and it all pooled above the floor in the 2nd bedroom. After calling the landlord and them not knowing what it was from - since the bathroom was not directly above us, but was running - they thought it was from an ice jam. A small brown spot in the ceiling turned into a larger brown spot, that turned into the start of a small bubble. Calls to the landlord didn't do much, and 2 days later the ceiling from that bedroom was on the floor. Luckily we had cleared everything out of there before it happened.
hyunelan2 is offline   Reply With Quote
Old 01-20-2011, 05:09 PM   #13
Rewards Points: 516
Upstairs situation could range from: unattended kids taking showers and not closing shower curtain correctly (easy fix), little kids splashing in tub (easy fix), loose tile that just need grout or sealant (easy fix), bad leaky plumbing (no so easy).
Unless you are very friendly with neighbor, let landlord take first shot at getting a solution.
Old 01-22-2011, 05:49 PM   #14
waterman1971's Avatar
Rewards Points: 154
I vote for you to pop it. Please upload video if possible
waterman1971 is offline   Reply With Quote
Old 01-23-2011, 04:01 PM   #15
Tizzer's Avatar
Rewards Points: 470
It's in your landlord's benefit to have it fixed now. Me, I wouldn't mess with it until you contacted them. The longer your landlord waits, the more sheetrock will get damaged($$$$). Not to mention mold.
The apartments where I work have bathrooms stacked over each other. The tenant above you may not know he/she has a leak if its a bad toilet wax ring or a leak behind the shower wall.
Print that picture and take it to the landlord.
Tizzer is offline   Reply With Quote
Bathroom: Bare Green Drywall & Moisture drex Building & Construction 6 07-08-2012 08:02 AM
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 12:04 PM
Installing towel hanger shelf through bathroom tile and drywall zeramuas Kitchen & Bath Remodeling 3 01-14-2011 07:01 AM
Bathroom Remodel - Wish I had done it myself JeremyEB Drywall & Plaster 12 02-07-2010 10:52 PM
Drywall bathroom ceiling docproteus Building & Construction 5 01-10-2008 07:05 AM
