How Would You Repair This Rotted Door Jamb. (pic Inside) - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 01:24 PM   #16
Might need a gutter if you are getting this much rot.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-02-2009, 01:20 PM   #17
This guy had the same problem, here is his step by step solution.
http://www.hammerzone.com/archives/d...b/rot/wood.htm
mcalpin5 is offline   Reply With Quote
Old 07-02-2009, 02:43 PM   #18
Rewards Points: 346
I live in a PA condo and in my association that would be covered by the HOA. I believe every state has a uniform condominium act or something similar like PA has. So even if you agreement does not say that is covered your state law may require it to be covered. If the later is the case you would need to decide if it is worth fighting or not.
RegeSullivan is offline   Reply With Quote
Old 07-02-2009, 03:30 PM   #19
Thanks guys,
I did state my case to the association and I am awaiting their "verdict" before I proceed. And if I do end up having to do it myself, that link was most helpful, Thanks MCALPIN5.
But I noticed that the guy used an oil based primer with a latex paint on top. That's a no-no, and that I know!
landgirl is offline   Reply With Quote
Old 07-02-2009, 04:30 PM   #20
Actually outside I use oil base primer exclusively w/latex on top
Old 07-02-2009, 04:38 PM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Ditto - just don't go the other way around.
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Repair rotted wood core in exterior metal door. jnowak Building & Construction 2 05-04-2009 04:55 PM
Repair Top of Rotted Floor Joist nightsurfer General DIY Discussions 18 02-27-2009 12:11 AM
Roofers.. Repair inside damage from re-roof? ShortEdged Remodeling 13 12-28-2007 06:58 PM
How to repair deterioration on inside of window frame? darsunt Carpentry 2 08-13-2007 03:40 PM
