How Would You Go About Fixing A Gutter? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 09:38 AM   #1
Send a message via AIM to fatpig
how would you go about fixing a gutter?
my gutter is leaking and everything i try never fixes the problem. it leaks by the joints. i tried putting the mesh on the joints but that didnt work either and now im running out of options.
fatpig is offline   Reply With Quote
Old 03-05-2009, 10:11 AM   #2
Remodeling Contractor
Be sure the joints are aligned and sealed with gutter mastic. Each joint should be attached with pop rivets. The gutter should have a straight line (no sags) and pitched towards the downspout. If all of these things are addressed you should have no problems. Be sure to clean the joints completely prior to applying the mastic.
Old 03-05-2009, 10:14 AM   #3
the Musigician
DangerMouse's Avatar
joints as in two pieces joined, or where the downspouts connect? or both? i've had limited success with short-term repairs of cleaning the area completely and using a silicone caulk. however, your best bet, if you're handy on a ladder, is to call any service that makes seamless on the spot and you do the install, MUCH cheaper that way!
DM
Old 03-05-2009, 10:34 AM   #4
No much better, but much more money. Use Gutter mastic ... better than silicone, but silicone Type I will work also. Clean area with denatured alcohol first.
Old 03-05-2009, 09:09 PM   #5
Did you try caulking that joint at all? If not you may want to try that. If you have done that maybe you can try standing away from your gutter and looking along side of it to see if the joint is creating a dam. Damming is very common with gutters if not properly installed.
Peeps is offline   Reply With Quote
Old 03-06-2009, 03:59 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This is one of the reasons people go with seamless gutters.
- Build Well -
Old 03-06-2009, 04:16 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
i bet the seam is right over your door too so that everytime you go out the door you get dripped on
Tom Struble is offline   Reply With Quote
Old 03-06-2009, 04:36 PM   #8
Reminds me of one of the job estimates I am working on. About 80 apt units with gutters and seams above every entry door. Huge ice build ups and drainage problems. Going to replace with seamless.....Geniuses:
- Build Well -
Gutter Heaters kennykenny Roofing/Siding 17 02-29-2012 02:43 PM
"Frozen" Gutter Leak cougar01 Roofing/Siding 19 02-10-2009 06:07 AM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 12:57 AM
