How Would You Fix This Cosmetic Ceiling Issue? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-23-2007, 11:29 AM   #1
How would you fix this cosmetic ceiling issue?
I accidentally ruined my ceiling a few days ago with tape.
The photos were taken up close.
As you can see, the paint (or whatever it is) is very thin and peeled away like paper.
Any recommendations? Thanks a lot.
tinhouse is offline   Reply With Quote
Old 08-23-2007, 11:30 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Coat the damaged areas with joint compound as needed. Sand, prime and paint.
- Build Well -
Old 08-23-2007, 11:34 AM   #3
Thanks for the fast reply.
Old 08-23-2007, 01:09 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Looks like the whatever affected the "paper" part f the sheetrock
It may need a coat of oil-based primer, or Zinsser's Gardz before applying joint compound, to keep the j/k from lifting
Hard to tell from here
slickshift is offline   Reply With Quote
Old 08-24-2007, 10:45 AM   #5
Mod / ArchiBuilder
Cole's Avatar
This should be an easy fix.
Cole is offline   Reply With Quote
Old 08-24-2007, 11:42 AM   #6
Yup--got the supplies last night and will take care of it tomorrow. Thanks for the help everyone.
Old 08-24-2007, 12:12 PM   #7
Mod / ArchiBuilder
Cole's Avatar
Just remember to feather out the joint compound so that is blends in seamlessly.
No one will know that you had that problem before.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 03:47 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
